Author Topic: SL280 squeak noise rear wheels increases and decreases with speed of car.  (Read 2904 times)
thomas wright
I have a rotational squeaky noise from the rear wheels . It's frequently increases  then decreases with the speed of the vehicle.
I thought it might have been the discs or hand break but the sound continues when I apply both.  I wondered if it might be wheels bearing or something in the axel gearbox.
I would appreciate any suggestions from any experienced member.
Thank you
Tom.   ( in England)
Charles 230SL
  • USA, GA, Griffin
  • 64 230SL
hi Tom, I had a similar "squeak" several years back; ended up being the rear universal joint. vr,,,chas
Alex D
  • USA, NC, Cary
Hi, I have the same issue as described. Rear brakes checked out ok. Currently having the drive shaft rebalanced and new u joints installed next week, will see if this fixes it like Charles. If drive shaft and u joint don't fix then trail arm bushings.
Alex D
1967 250 SL
Original 140K mi
181 Light Beige, with  112 Turquoise Interior
Maybe one of the backing plates that is touching the brake disk. Or a small stone caught between the disk and the plate.
thomas wright
Thank Charles,  I didn't  think of that as the cause but I will definitely consider it.
Many thanks,
thomas wright
Hi Alex
It seems from what you say it can be difficult to pin point the problem and could result in unnecessary work until you find a cure. I haven't facilities to do the work myself so use a local SL experienced engineer which can ramp up the cost unfortunately.  I have scheduled to deliver the car to them next Tuesday for a fault-find mission and will let you know the outcome.
Alex D
  • USA, NC, Cary
Hi Tom,
These are things I needed to do regardless of the squeaking, initially it looks like the rear breaks are fine, rebalanced drive shaft with new u joints next week and by mid/end of March will have new trail arm bushings.  Will let you know what I find.
If anyone else has any suggestions I am willing to listen and try.
Alex
Alex D
1967 250 SL
Original 140K mi
