Author Topic: 220S 220SE 230SL 250SL 250SE 280SL 280SE Front Crank Seal Easy Install Tools  (Read 2895 times)
GM
  • USA, CO, Boulder
Hi all,
I saw this on YouTube last night - https://www.youtube.com/watch?v=Eo1z4ISfRp4
Gary
1971 280SL - Sold
DB180 Silver Gray Metallic
Black MB Tex
doitwright
  • USA, IL, Willowbrook
Looks like Kent uses a 2" PVC cap shortened with a hole drilled in the center, large washer with OD slightly larger than the seal, and 1-1/2" or 1-1/4 PVC pipe slotted to expand over the crankshaft, an additional slotted metal sleeve to fit over the slotted PVC pipe and some grease.
This reminds me of my race removal tool using a 6" long piece of 2" PVC pipe slotted to expand and fit over the race. Add some hose clamps to compress the PVC over the race and twist off or use a dent puller like tool to remove the race.
Frank Koronkiewicz
Willowbrook, Illinois
I just use this.  Works great.
Sorry.  Couldn’t resist.
doitwright
Hey Pat
That looks like one of those NLA, expensive and proprietary MB tools.
Frank Koronkiewicz
Rick Katucki
  • USA, ID, Eagle
Might be able to find a big socket that will work too.
Rick Katucki
64 230SL
Manual
Idaho, USA
Frank,
It is.  I was lucky enough to be given a bunch of tools many years ago.  I passed on most to a friend but kept a few for the M130 engine.
doitwright
Pat
Good for you. How did you figure out what is was for?
When I need one, I'll be going to Home Depot.
Frank Koronkiewicz
Frank,  I bought a copy of an old tool manual and spent a few days digging through part numbers.  I can pretty much identify the W113 tools by sight now.
Here is the whole set from L to R:
Hub puller, wear ring puller, hub installer and seal driver.
« Last Edit: February 21, 2021, 14:09:23 by Shvegel »
