Author Topic: 66 230 piston rings  (Read 3270 times)
MarkCan
  • Canada, Ontario, Mississauga
66 230 piston rings
« on: January 23, 2021, 12:35:06 »
I look at Hastings piston rings and there are few options listed. It all got little more complicated when I put the Mahle piston in to the mix. I don’t see a catalog listing for it. There is one for 250 though. The same 82.00mm bore, although the top ring is thicker (2mm). Definitely not the one.
I would like to know if the Mahle piston uses the same specks rings as the original Mercedes piston.
I appreciate your input very much.
balimatharu
  • United Kingdom, England, Coventry
Re: 66 230 piston rings
« Reply #1 on: January 27, 2021, 21:38:41 »
I had somewhat similar situation. Last year I  reconditioned my 250sl engine. It has original Mahle pistons 81.98mm.
Mercedes Classics of Germany supplied me with Mahle rings. But they were not the right ones. See the table below.
                Ring A.    Ring B.   Ring C
Original.    5mm.       2.5mm.  1.4mm
Supplied.   4mm.       2.5mm.  2mm
                  Too.          Ok.       Too
                   Thin.                    Thick
Alex at MB Classic said he can’t find the rings for my pistons. He said I will have to buy new set of pistons.
I started hunting over internet. One guy contacted me to say he got the rings for my car. Made by Hepolite for Mercedes. Perfect match.  Look at the photo.
Bali
MarkCan
« Reply #2 on: January 28, 2021, 20:15:06 »
Bali, thank you for posting your leads.
I’ve been at it steady and found some single rings to make a required set.
I’ll post it all here once I have it all in my hands and can physically confirm the fit.
« Reply #3 on: January 29, 2021, 22:52:06 »
Call Deves rings.  Great product and good people.  They will make up a set for you with what you need.
Esmo
  • United Kingdom, Wales, Conwy
  • SL 230 1967
« Reply #4 on: January 30, 2021, 11:31:53 »
The confusion regarding piston rings is probably due to the fact that 3 different generations of pistons were fitted to the SL230 .
Generation 1  with 4 rings ,24 mm bolt .
Generation 2 ,3 ring ,24 mm bolt .
Generation 3 ,3 ring , 25 mm bolt.
Each generation was also available in 3 sizes 82mm ,82.5mm and 83mm . I have researched this after I purchased in error  a full set of 83mm Gen 2 MB pistons (for sale at half MB price. ) .
I believe all MB brand pistons were manufactured by Mahle for MB .
