Author Topic: Which blower switch for 64/65 230 SL?  (Read 5518 times)
Ulf
« on: January 04, 2021, 16:16:43 »
Happy New Year to you all. I'm thinking about replacing the blower switch in my 230 SL as I suspect that it might be related to the issues I've had with the cold starting (mentioned in a previous) post as the short fuse that both feeds the CSV and blower motor kept blowing (the fuse that is...). Besides, the blower doesn't have much power. But I've noticed that there are two different ones (both equally pricey), one with 4 connectors and one with 5 (see attachments). Which one is the correct for a 230 SL?
Br
Ulf
1965 230 SL in silver (DB180)
2008 Jaguar XF 3.0
2005 Mini Cooper
Re: Which blower switch for 64/65 230 SL?
« Reply #1 on: January 04, 2021, 16:26:02 »
My guess is that the five pin switch has the small light for the blower knob?
scoot
  • USA, CA, Altadena
« Reply #2 on: January 04, 2021, 19:05:16 »
The top one.  It has a lightbulb.  That is useless.
Scott Allen
'67 250 SL (early)
Altadena, California
Ulf
« Reply #3 on: January 04, 2021, 22:05:38 »
Thanks a lot :-)
2008 Jaguar XF 3.0
2005 Mini Cooper
scoot
  • USA, CA, Altadena
« Reply #4 on: January 04, 2021, 23:10:18 »
Wait a minute, this still doesn't look right.  The potentiometer should have a fiber coming out at the tip of the shaft - that's how the (useless) light comes out.  I can't see that in the picture...
Scott Allen
'67 250 SL (early)
« Reply #5 on: January 05, 2021, 07:21:50 »
I thought the early cars did not have the light? Check your plug to see how many wires it has.
scoot
  • USA, CA, Altadena
« Reply #6 on: January 05, 2021, 14:30:52 »
You may be correct.  I agree, take out old switch and see what it has, whether or not it has a fiber at the end of shaft (rigid fiber) AND does your existing knob have a tiny hole in the end???   By the way, in case you haven't taken one of these apart before, DON'T pull off the knob.  The knob comes off as a single unit with the chrome bezel.  Unscrew the bezel, then the knob comes out with the bezel.
Scott Allen
'67 250 SL (early)
« Reply #7 on: January 05, 2021, 21:23:44 »
Yes...,
illuminated.
All 230ies and early 250 SLs (up to the famous serial no. 002979) had the illuminated knob on the blower switch.
Also when built before July 1963.
 :o
scoot
  • USA, CA, Altadena
« Reply #8 on: January 05, 2021, 21:44:07 »
illuminated.
If that is the case, than neither of the above pictured blower switches are correct, as neither has the fiber optic cable to provide the illumination...
Scott Allen
'67 250 SL (early)
« Reply #9 on: January 05, 2021, 21:58:58 »
Yes..., Scott,
That is my understanding.
The upper one (with the four copper-colored contacts) on the pics posted by Ulf _should_ also have the fiber optic cable,
which is missing there.
Appears to me to be one of the available new repros and no NOS. Maybe...
But it has got the little clamp that (should) hold the illumination bulb, which the lower one (the one with three contacts) is missing.
The fiber optic cable can be refabricated and applied to that switch if desired.   Friend of mine did that on his 230.
scoot
  • USA, CA, Altadena
« Reply #10 on: January 05, 2021, 22:17:34 »
It should look like this:
Scott Allen
'67 250 SL (early)
Paul99
  • 230 SL White. 1966.
« Reply #11 on: January 12, 2021, 12:39:54 »
my 230 has the optic light, but found the old bulb was so hot overtime that it overheated the unit and became very brittle.  i did try to get the light working - it was slightly less bright than a gloworm on a bad day. So didn't bother to refit the bulb.
I guess an LED bulb would work?  But the optic bit is so small.
« Reply #12 on: January 12, 2021, 12:57:09 »
Sorry, just for my knowledge: is it the fiber that should stick out of the switch shaft or the bulb?
I see the bulb sticking out of the shaft on the picture, not the fiber. In such case the switches in question may simply not have the bulb installed, but both of them seem to have an opening at the end of the shaft for something, e.g. the bulb...
scoot
  • USA, CA, Altadena
« Reply #13 on: January 12, 2021, 15:01:28 »
My recollection is that the fiber sticks out the tiniest amount in front of the knob, but it might be that it's just inside the knob.  It's supposed to be how it looks in the (correct) pictures and as others have mentioned, it's about as bright as a glow worm on a bad day.
Scott Allen
'67 250 SL (early)
« Reply #14 on: January 12, 2021, 16:05:39 »
Why then do I see a bulb sticking out on your picture?
scoot
  • USA, CA, Altadena
« Reply #15 on: January 12, 2021, 16:10:57 »
That's not a bulb.  That's the fiber.  The knob/bezel slides over that and screws on.
« Last Edit: January 12, 2021, 16:16:57 by scoot »
Scott Allen
'67 250 SL (early)
« Reply #16 on: January 12, 2021, 16:54:40 »
Thank you, this is what confused me!
If you do not know exactly what to expect - I could swear it was a bulb!  :)
