Author Topic: Late rear view mirror disassembly  (Read 3297 times)
GM
  • USA, CO, Boulder
« on: December 21, 2020, 00:40:54 »
I've searched the Tech Manual and all comments on the Forum, but can't seem to find any help for disassembly of my late 280 rear view mirror problem: rattling lever and the day/night mirror doesn't flip.
I can see inside through the lever opening and it looks like there's an internal screw holding the stalk to the mirror which might need tightening, but I can't figure out how to get in there to do it.
The edge of the plastic mirror case halves look to be very tight, and I've seen comments referencing heat, but only generally - nothing specific.
Anyone have any tips/hints about the procedure for how to disassemble the mirror so I can tighten it?
Gary
1971 280SL - Sold
DB180 Silver Gray Metallic
Black MB Tex
col320ce
Re: Late rear view mirror disassembly
« Reply #1 on: December 21, 2020, 02:16:55 »
Not sure if there is a difference in construction but on my 230sl I used 4 guitar picks to get under the catches to pull it apart. A little fidly but it hard.
Col
1964 230SL
1965 250SE coupe
1993 320CE Sportline
GM
  • USA, CO, Boulder
« Reply #2 on: December 21, 2020, 04:11:05 »
Thanks, Col.
From what I've read, the 230s are easier to get apart than the later ones.
What a shame, my picks have been abandoned for a while!
Gary
1971 280SL - Sold
Black MB Tex
WRe
« Reply #3 on: December 21, 2020, 08:12:10 »
soak the mirror in (60°C) warm water. Push the glass with both thumbs under water in one direction, lift the glass a bit through the resulting slot and push the glass out of the plastic housing in the opposite direction.
Because the fastening ball must be locked in place before inserting the mirror, otherwise the mirror will be broken, as the effort required to enter the ball joint is greater than to remove it.
...WRe
GM
  • USA, CO, Boulder
« Reply #4 on: December 21, 2020, 17:12:16 »
Thanks, WRe...I think.
Gulp - sounds like a risky job. I need to think about this.
Gary
1971 280SL - Sold
Black MB Tex
wjsvb ✝︎
  • USA, VA, Virginia Beach
« Reply #5 on: December 21, 2020, 18:20:07 »
As a temporary (or permanent) fix, a mirror from a 108/109 will work.  It will be slightly larger but snaps right in.
jon
67 250SL early
81 280SL Euro 4spd
GM
  • USA, CO, Boulder
« Reply #6 on: December 21, 2020, 18:49:39 »
Thanks, Jon.
Gary
1971 280SL - Sold
Black MB Tex
