Author Topic: GOOD FUEL INJECTORS  (Read 4744 times)
perry113
  • USA, NY, Rensselaer
GOOD FUEL INJECTORS
« on: December 14, 2020, 14:13:19 »
I have seen posts regarding new fuel injectors being bad right out of the box.
Does anyone have any good known fuel injectors?
I am open to at least 1 to a full set.
Peter Perry
1969 911T Tangerine
dirkbalter
  • USA, CA, Corona
Re: GOOD FUEL INJECTORS
« Reply #1 on: December 14, 2020, 16:54:28 »
Peter,
I was in the same situation. Have you considered buying a test unit? It lets you test your old ones and verifying possible new ones work correctly. It gives you a piece of mind that knowing the injectors are good prior to putting them in.
https://mercedessource.com/store
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
WRe
« Reply #2 on: December 14, 2020, 17:41:48 »
I support Dirk because old  injectors are sometimes better than new ones and it's really easy to test them even to build your own test equipment. You can get a test unit for less than one injector would cost. There are also special workshops which can test and clean your old injectors.
...WRe
« Reply #3 on: December 14, 2020, 18:04:34 »
I bought an injector tester here https://www.fiptestbenches.com/injector-nozzle-testers.html
Works well for our gas injectors and I believe is under $100. The gauge is more for higher pressure diesel, but can be changed. I use Kerosene in mine to test. You really want to see the spray pattern and the fact that the injector shuts off and doesn't continue to dribble. This tester will do that. If you have the early 220SE injectors, which are near impossible to find, using a tester is invaluable and highly recommended.
perry113
« Reply #4 on: December 15, 2020, 02:28:53 »
This is a great idea.
In meantime I am looking for some known good spare injectors.
Email me if you injectors.
peterperry911113@gmail.com
Peter Perry
1969 911T Tangerine
cabrioletturbo
  • Canada, Ontario, Ottawa
« Reply #5 on: December 15, 2020, 15:30:06 »
sent email
Igor
MarkCan
  • Canada, Ontario, Mississauga
« Reply #6 on: December 17, 2020, 03:53:59 »
Hey Peter,
Did you find your injectors?
Looks like I’ll need some as well.
