with our official
Pagoda SL Group logo
from our official partner.
4th speed on automatic transmission stopped working
Topic: 4th speed on automatic transmission stopped working (Read 3041 times)
jesraymond
December 06, 2020, 13:07:21 »
4th speed on automatic transmission stopped working. Fluid level good transmission works fine otherwise anyone have any recommendations? Do I Need a transmission rebuild The car is a 1970 280 SL
Full Member
Platinum
Re: 4th speed on automatic transmission stopped working
December 06, 2020, 13:37:18 »
Are you sure?
They normally start in 2nd, so only change gear twice.
What sort of RPM are you seeing at 40mph? 50?
jesraymond
Reply #2 on:
December 06, 2020, 13:40:47 »
I’m running about 3000 RPMs between 40 and 50 miles an hour
Tyler S
Associate Member
Platinum
USA, CA, Encinitas
Reply #3 on:
December 06, 2020, 18:44:50 »
Does it also shift late and hard? There may be an issue with the kickdown solenoid or switch stuck
Associate Member
Platinum
USA, OH, Cleveland Heights
Reply #4 on:
December 07, 2020, 03:29:33 »
d guess you 3 position solenoid is stuck. Essentially your transmission thinks you are mashing the gas pedal. Been written about a bunch here so search it and free it up.
Full Member
Platinum
USA, OH, Blacklick
Reply #5 on:
December 08, 2020, 00:12:09 »
Sometimes, just the kick-down-button on the floor gets stuck down. It's easy to check this first.
