Author Topic: W11X handbrake damper  (Read 3912 times)
col320ce
« on: November 26, 2020, 21:44:22 »
I had an oli leak behind the dash ind it damaged the rubber damper for the handbrake. How and what needs removing to replace it?
I've included a picture from the web with an arrow pointing to the damper... Mine is still in the car.
Thanks!
Col
1964 230SL
1965 250SE coupe
1993 320CE Sportline
PeterPortugal
  • Portugal, Faro, Lagoa
Re: W11X handbrake damper
« Reply #1 on: November 28, 2020, 08:25:07 »
Hi Col,
I did this recently and if you want to replace that rubber buffer you have to disconnect the cable at the front of the car and take the handbrake lever out.
There is a guide pin on the top of the rod with the notches for the ratchet. This pin will stop you fully withdrawing the rod which you will have to do to replace the rubber piece. The guide pin is an interference fit and you can drive it out by lining up the pin with a hole in the underside of the tube. The hole is made for this purpose. Mine took a real beating before it came out hence why you have to take the lever out !
It's all time consuming but do-able. See the pic. Anymore questions, just ask.
1963 220se Cabrio
1968 280se Coupe
col320ce
« Reply #2 on: November 28, 2020, 10:26:06 »
Thanks Peter!
I'll try and do it tomorrow.
Col
1964 230SL
1965 250SE coupe
col320ce
« Reply #3 on: November 29, 2020, 06:11:49 »
Done... 2 x 10mm bolts at the handle end need to be removed and unhook the cable from the left front corner of the car. I was able to get enough slack without pulling through the whole cable but you're right about needing to beat the living daylights out of the pin!
The cable can then be disconnected from the handle.
Col
1964 230SL
1965 250SE coupe
