Author Topic: 1969 280SL engine shut-off  (Read 2959 times)
TBaker
  • USA, TN, Germantown
« on: November 16, 2020, 19:15:40 »
Recently when I turned the ignition off, the engine and fuel pump continued to run and the only way I could get them to stop was by shutting the driver side door or pushing the door button.  Any idea what is going on?
CJHenderson
  • USA, AR, Benton
Re: 1969 280SL engine shut-off
« Reply #1 on: November 16, 2020, 19:46:47 »
Is it possible that that you have a loose wire in the steering column?
1970 280SL/8 W113 101624 miles.
1950 MG-TD
2021 Harley Davidson CVO Trike
« Reply #2 on: November 16, 2020, 21:18:42 »
The light for your door and the low-level warning on your brake fluid canister is on the same circuit. Pacing a diode on the circuit will fix that.
Iconic
  • USA, IL, Highland Park
  • ex-Membership Administrator
« Reply #3 on: November 17, 2020, 13:14:18 »
Dan, Isn't it also true that if TBaker adds the correct amount of brake fluid, the issue will be gone as long as the circuitry is "correct" and working as intended?
Take care,
Mark
1998 BMW M-Rdstr Estoril Blue
« Reply #4 on: November 17, 2020, 14:59:49 »
Take care,
Mark
Sure. Sometimes though, that can't be done in a remote location, or the float will become disconnected and/or leak which makes the fluid level warning system inoperative.
Iconic
« Reply #5 on: November 17, 2020, 15:04:42 »
Thanks Dan.
TBaker, Dan knows his stuff !! Also, this is a well known issue that is covered in many posts.
The search button is your friend.
Enjoy the ride,
Mark
