Author Topic: Lifts  (Read 8688 times)
Harry
  • USA, TN, Knoxville
Lifts
« on: October 14, 2020, 11:19:38 »
I am trying to decide which type of car lift to install in my garage - 2 post or 4 post.  It will just be for my personal use to work on my own vehicles, mostly oil changes, brakes, and miscellaneous tasks.  (It will also afford me the ability to pay some attention to the underside of the 230SL.)
The 4 post clearly provides the benefit of storing the vehicle overhead but since the car rests on its wheels, doing brake work requires that I use a jack on the lift as well.  It also limits the access a bit since the runways are present.
The 2 post provides unhindered access but can't be used to store the car.  And I wonder about how good it is to let the suspension dangle on this type of lift.
The fact is that I don't need the storing capability, even though that is an attractive feature.  And the suspension hanging on the 2 post would not be a long term proposition.  (I believe that at its extent, the suspension is captured by the shock absorbers as well.)
I am leaning towards the 2 post but I would welcome some additional advice from those on the forum who have either type of lift.  What has your experience been?  Are you happy with the type of lift that you have?  Does a 4 post provide the desired access at the wheels?  Advantages/disadvantages of each type?
Thanks very much,
Harry
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
  • USA, WI, Mequon
Re: Lifts
« Reply #1 on: October 14, 2020, 13:14:17 »
Can't store on a two post?  Did it for years without issue.
You've already identified the pros/cons of each.
Jordan
  • Canada, ON, Jordan
Re: Lifts
« Reply #2 on: October 14, 2020, 14:18:04 »
One item you forgot which may or may not make a difference depending on your situation.  A 4 post can be moved, even with a car on it, while a 2 post is fixed.  I have a 4 post and am very happy with it.  Comes with trays that cross the ramps so you can use jacks to lift the front or back if you need to work on the wheels if need be.
Marcus
66 230SL  Euro 4 speed
Re: Lifts
« Reply #3 on: October 14, 2020, 15:01:35 »
Aside from the "pros and cons" there are other considerations:
power
height
mounting
Be sure you can easily get the proper power to it. I don't know if any are a simple (USA/Canada) 110V, but a higher amperage 220V feed is more common. This may or may not pose some install issues.
Height: some have minimal garage heights. Check before you buy...
Mounting: need to check the quality of your garage floor before installing these. Some can bolt with the proper mounts, others may require small footings. All are doable, some just more troublesome than others.
Another consideration for those with "normal" roll up garage doors, is that they may interfere. They do make side mount garage door openers, and the tracks can be extended such that the door rolls close to the ceiling instead of just 8' up.
Just some thoughts...
Harry
Re: Lifts
« Reply #4 on: October 14, 2020, 15:47:39 »
Thanks very much to all!
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
Re: Lifts
« Reply #5 on: October 14, 2020, 18:46:43 »
I thought about a lift, but have found I can do everything I need to without one. I even built my own 'lift' and could have made it a lot taller than I did - cost me around $100. I am doing a ton of underbody work on this car now:
Bonnyboy
  • Canada, BC, North Vancouver
  • 1969 280sl Euro 4sp LSD
Re: Lifts
« Reply #6 on: October 14, 2020, 19:06:27 »
Have you thought about a mid-rise scissor lift - you can drive the right over the lift when not in use and can get to most items underneath the car still sitting on a low profile rolling stool.    I borrowed one and within a day I knew I needed one  - I don't have the height in my garage to get much more elevation than I can get with the lift.  Great for suspension / brakes.   Only slightly less expensive  than the larger lifts but I can wheel the lift into the back lane if I need to.    If you have a lower car you just drive up on boards.
Since I got mine two friends have also gone with a mid rise lift.
Ian
69 280SL
73 CB750K
75 MGB
78 FLH
82 CB750SC
83 VF 1100C
94 FLHTCU
96 F-150
08 NPS50
12 Pro 4X
ejboyd5
  • Southold, NY
Re: Lifts
« Reply #7 on: October 14, 2020, 20:41:17 »
I have long thought that a two post lift using wheel adapters such as shown in this picture would be good for our cars,
Re: Lifts
« Reply #8 on: October 14, 2020, 21:14:05 »
After several years looking and researching lifts, i have just had installed a two post lift with wheel adaptors. I opted for three phase power to the lift, and have not even commissioned it yet.  If necessary they can be unbolted and moved although i am not planning to move again other than in a box :o :o
My reasoning is that i want to use it as storage if needed and thus the wheel lifts which are rare here in OZ.
Re: Lifts
« Reply #9 on: October 14, 2020, 21:14:16 »
On the need for lifts or not, I have to take this opportunity to share this photo once again. This was done for a 190SL by a friend's father when he was in his 90s. Apparently he did this (jerry-rigging a lift of sorts) all by himself. The car was never really completed however...but A+ for effort. The man passed a long time ago...
Re: Lifts
« Reply #10 on: October 15, 2020, 12:10:07 »
A two post prevents opening the doors fully. If the lift doesn't have it's own frame to stand on you MUST be sure that your floor can withstand the loads. I have personally witnessed the collapse of a two post ramp that lifted itself out of the floor bringing a large chunk of the floor with it.
I have a mix in my workshop and both ramps have individual benefits but if I could only have one it would be a two post.
merrill
Re: Lifts
« Reply #11 on: October 15, 2020, 13:04:50 »
i have always liked the drive up type lift that is used in alignment shops
allows you to drive the car up onto a secure platform,  lift the car a few feet for access between the wheel rails and has a smaller lift within that allows one to raise or lower either end of the car if you need to remove the wheels .
they are expensive
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
Re: Lifts
« Reply #12 on: October 15, 2020, 16:22:18 »
A typical residential garage floor in the USA just done by a builder or concrete guy w/o any further specification, would be something like maybe 3" (75mm) of concrete, nominally. That means some parts may be thicker some may be thinner. Without further specification, they'd use 3000 psi ("4-sack mix") concrete. There would be a nominal few inches of sand as a base, and no mesh reinforcement. When they do this stuff they are not thinking of people like car collectors who may want to put in a lift!
So, based on Stick's observation, I would think what he saw wasn't the first time something like this happened!
Re: Lifts
« Reply #13 on: October 15, 2020, 16:41:27 »
A local kid was killed a few years back when the truck he was working on fell on him. He was using concrete blocks to hold it up. Blocks crumbled and he couldn't get out of the way in time.
I'd give both of them a D- for those brilliant efforts.
johnk
  • USA, OH, Avon
Re: Lifts
« Reply #14 on: October 15, 2020, 17:41:20 »
reading all of this I started to like the idea of a two post lift over a four post for my three car garage. however I just realized that the position of the posts would make is difficult to get out of the car next to it without banging the doors on the post.
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
Bobmog
  • USA, AK, Cheyenne
Re: Lifts
« Reply #15 on: October 15, 2020, 18:07:13 »
Similar 2 post vs. 4 post lift discussion on the G-Class forum recently.
https://www.clubgwagen.com/forum/viewtopic.php?f=42&t=17372
doitwright
  • USA, IL, Willowbrook
Re: Lifts
« Reply #16 on: October 15, 2020, 21:21:23 »
YouTube search “car lift ideas” for all kinds of lifts including a single post
For some giggles and “not with my car” lift ideas check DIY car lifts
Frank Koronkiewicz
Willowbrook, Illinois
Re: Lifts
« Reply #17 on: October 16, 2020, 00:49:08 »
Mine is bolted down through 200mm (8”)  of reinforced concrete.  I don’t think it’s going to fall any time soon.
  • USA, WI, Mequon
Re: Lifts
« Reply #18 on: October 16, 2020, 01:54:21 »
If you have the height, an overhead is the way to go with a two post to avoid the floor plate for the hydraulics and latch cable.  Not the best pics, but you get the idea.  Also, an asymetrical 2 post gives adequate room to open the doors on the lift.  Mine is a BendPak 10K lb.  Only negative, first latch is 24" off the ground, aa bit high for me to sidle up to the car and work in the engine bay which I like to do on a lift to save my back from bending over the bay.  I can lower it an let it be supported by hydraulics, not a big deal, I'm not standing under the car.
ejboyd5
  • Southold, NY
Re: Lifts
« Reply #19 on: October 16, 2020, 11:46:51 »
All this being said, I'll stick with the "root cellar" that I've been using for 35 years. It affords the ultimate in stability and access as well as providing good exercise climbing down and up the stairs at each end.
Re: Lifts
« Reply #20 on: October 16, 2020, 14:12:44 »
Clearly something was amiss with this and you do NOT have the entire story. How many blocks? What was the orientation? How heavy was the truck? Even mediocre concrete has compressive strength of 3000 PSI (PER SQUARE INCH!) and very few driveways or garages crack or fail with the weight of a car OR truck on them. Now, a 10 yard fully loaded CEMENT TRUCK delivering concrete to MAKE a driveway? Yeah, that will crack an existing driveway in a heartbeat.
Re: Lifts
« Reply #21 on: October 16, 2020, 14:13:38 »
I LIKE IT!
yves
  • France, Poitou-Charentes
  • Happy owner of a 69/ 280 sl , 63 Etype ,55 XK 140
Re: Lifts
« Reply #22 on: October 16, 2020, 19:45:15 »
That's what i have built....
Happy owner of a 69 blue 280SL ,  63 FHC  osb E-type , 55 FHC XK 140 to be restored...
yves
Re: Lifts
« Reply #23 on: October 16, 2020, 19:46:49 »
and more pics:
yves
Re: Lifts
« Reply #24 on: October 16, 2020, 19:57:09 »
some more pics :
