Author Topic: Door sill trims  (Read 4683 times)
Brenco
Door sill trims
« on: September 25, 2020, 18:01:35 »
Here is a question about the door sill trims on either side of the ribbed inlays. Just wondering what they are made of? Also are they chromed or polished metal?  I am looking into refurbishing them and trying to figure out what type of specialist to use. Mine is a 1969. US spec 280 sl in case model is relevant. Thanks in advance. B
Re: Door sill trims
« Reply #1 on: September 25, 2020, 21:18:52 »
Re: Door sill trims
« Reply #2 on: September 25, 2020, 22:25:45 »
Ther are aluminium and polish up.  If you try to purchase new ones, there is a problem if you are not in the same country that they come from so that they can be sent vis trucking, then using air mail postage and their length that exceeds a standard size and make the cost to post very expensive.
Brenco
Re: Door sill trims
« Reply #3 on: September 26, 2020, 10:02:25 »
I might try and get them refurbished or at least get a price on the job and compare it to the SLS price 400euro plus shipping for new trims. Thanks for clarification Pawel and Garry I had thought they were aluminium.
Re: Door sill trims
« Reply #4 on: September 26, 2020, 11:05:55 »
If it is just polishing, it may work, but if they were bent....
Maybe e.g. the SL shop sells them. Or MB - sometimes these things are not so expensive there.
Brenco
Re: Door sill trims
« Reply #5 on: September 27, 2020, 09:30:03 »
I’ll check out MB and a few other suppliers. Thanks again Pawel
Re: Door sill trims
« Reply #6 on: September 27, 2020, 10:03:44 »
I checked MB:
A 113 686 01 36
A 113 686 02 36
and
A 113 686 03 36
A 113 686 04 36
Will be around EUR 750 (no VAT, check prices in your place), but no shipment cost and bending risk.
Also: check out Niemoeller. I the SL shop I think they are more expensive vs. SLS/Niemoeller.
Brenco
Re: Door sill trims
« Reply #7 on: October 01, 2020, 22:35:14 »
More expensive than I thought then!! What a surprise 🤪. I will check the other suppliers too. I agree about the risk of damage in transit though. Thanks again Pawel.
Re: Door sill trims
« Reply #8 on: October 02, 2020, 01:50:45 »
They're soft aluminum and are anodized. It's kind of like chrome plating but much thinner so it can bend and not flake off the metal underneath.  Not repairable if they're dented and scratched up. The best method is to buy new ones - repro is available for modest savings.
Re: Door sill trims
« Reply #9 on: October 02, 2020, 11:58:47 »
I had dented ones that i gave to an old time chromer who fixed them and re polished them.  The cost was a whole lot cheaper than buying new ones with the shipping cost due to length being the killer.
Re: Door sill trims
« Reply #10 on: October 02, 2020, 13:24:50 »
I think you were lucky. I think "old time chromers" are in short supply...
Re: Door sill trims
« Reply #11 on: October 02, 2020, 21:26:37 »
Agree Pawel, most chromers will reject anything with dents and wont go to the effort of repairing. There is a good one that does a lot of hot rod gear near where I live, only problem it can take months to get the items back. ::)
Pinder
  • USA, NJ, Edison
Re: Door sill trims
« Reply #12 on: November 29, 2020, 00:39:20 »
They are aluminium and can be polished. (this will remove the anodized finish).  It is possible to remove most kinks and minor dents. It takes a lot of time. I started one. as shown in picture. It is not perfect but it looked like the one on the right. It had old paint on it, several dents and lots of scratches. It looks a lot better now. (see picture).
2015 BMW 320i xdrive
2021 Mercedes GLS450 Silver
cfm65@me.com
  • Cape Town, South Africa
Re: Door sill trims
« Reply #13 on: November 29, 2020, 18:20:57 »
Well done, Pinder.
Chris
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
