Author Topic: Steering pump supply fitting  (Read 2213 times)
BOOB
« on: September 17, 2020, 19:38:18 »
Hello everyone! Working on a ‘65 230SL. I have a quick question about the tube/elbow fitting on top of the power steering pump, where the supply hose from the reservoir attaches. I believe it’s an oring seal, please correct me if I’m wrong. I’m wondering if it’s a swivel assembly with a tube nut that spins freely on the tube or if it’s a solid assembly, which would mean I need to remove the pump to allow me to spin it off. I don’t want to remove the pump unless I have to.
dirkbalter
  • USA, CA, Corona
Re: Steering pump supply fitting
« Reply #1 on: September 17, 2020, 20:49:38 »
You don't need to remove the pump. Only the nuts spin once you loosen them.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
BOOB
« Reply #2 on: September 17, 2020, 21:01:13 »
Ok great! Thank you!
BOOB
« Reply #3 on: September 18, 2020, 22:07:22 »
It’s not an oring seal, it’s a double flare.
dirkbalter
  • USA, CA, Corona
« Reply #4 on: September 19, 2020, 19:48:19 »
looks similar to mine.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
