with our official
Pagoda SL Group logo
from our official partner.
Crankshaft mounting hub paint
Topic: Crankshaft mounting hub paint (Read 3146 times)
CJHenderson
Full Member
Gold
USA, AR, Benton
September 11, 2020, 14:30:29 »
Is there a special coating for the crankshaft mounting hub? I noticed that the coating on the mounting hub felt like it had a rubber type coating.
1970 280SL/8 W113 101624 miles.
1950 MG-TD
2021 Harley Davidson CVO Trike
Associate Member
Platinum
USA, OH, Cleveland Heights
Re: Crankshaft mounting hub paint
September 12, 2020, 08:15:16 »
The two halves of the hub act at a vibration damper and are bonded into one assembly at the factory by a layer of vulcanized rubber. What you see is most likely flash from the vulcanizing process and not an intentional coating.
CJHenderson
Full Member
Gold
USA, AR, Benton
Reply #2 on:
September 12, 2020, 12:33:06 »
Then the next question is, most of this rubber is gone and am not sure on how to proceed.
1950 MG-TD
Associate Member
Platinum
Reply #3 on:
September 12, 2020, 18:02:37 »
The rubber is actually between two plates if you poke at the edge of the disc you will feel it. Anything on the surface is superfluous. Clean it up, paint it black, put it back on.
CJHenderson
Full Member
Gold
USA, AR, Benton
Reply #4 on:
September 12, 2020, 19:54:50 »
Yeah that's the problem though, whoever had this car had the engine apart and scraped the insides.
1950 MG-TD
Associate Member
Platinum
Reply #5 on:
September 13, 2020, 01:54:40 »
Picture?
CJHenderson
Full Member
Gold
USA, AR, Benton
Reply #6 on:
September 13, 2020, 16:06:52 »
Here is the back side.
1950 MG-TD
Associate Member
Platinum
Reply #7 on:
September 15, 2020, 09:44:29 »
There was no rubber in the inside of the 6 pointed star area. At the very edge of the entire assembly you will find the rubber. it is sandwiched between the Aluminum and steel layers.
CJHenderson
Full Member
Gold
USA, AR, Benton
Reply #8 on:
September 15, 2020, 13:48:42 »
Yes and the rubber is gone on the sides.
1950 MG-TD
