with our official
Pagoda SL Group logo
from our official partner.
Crankshaft damper
Topic: Crankshaft damper (Read 2376 times)
CJHenderson
Full Member
Gold
USA, AR, Benton
Crankshaft damper
September 05, 2020, 12:36:07 »
Damper alignment keyway is damaged. Is there a replacement or is the damper shot?
1970 280SL/8 W113 101624 miles.
1950 MG-TD
2021 Harley Davidson CVO Trike
cfm65@me.com
Associate Member
Gold
Cape Town, South Africa
Re: Crankshaft damper
September 05, 2020, 13:07:21 »
CJ,
I believe those are loose pins.
Chris
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
Full Member
Platinum
USA, OH, Blacklick
Reply #2 on:
September 05, 2020, 14:41:11 »
Is the keyway itself damaged or just the pins? What model Pagpda?
CJHenderson
Full Member
Gold
USA, AR, Benton
Reply #3 on:
September 05, 2020, 15:01:11 »
Just the one pin
1950 MG-TD
Full Member
Platinum
USA, OH, Blacklick
Reply #4 on:
September 09, 2020, 14:29:15 »
Try replacing the pins with new. Also the BBB gives a procedure on re-working the assembly so you can use the later larger pins if all else fails.
Crankshaft damper
