Author Topic: Wind screen  (Read 5156 times)
balimatharu
  • United Kingdom, England, Coventry
Wind screen
« on: September 04, 2020, 17:30:52 »
I don’t think this would be a new topic. Could have been dealt with before.
My RHD California is nearly coming to the end of “ nut and bolt” restoration.
The wind screen is two tone green colour. It has a sticker saying Royal Doulton Vinilex laminated. It could be original. The screen looks good with no scratches or stone chips. Only problem is that in the bottom corners, the vinyl has bubbled. Only noticeable if you look closely.
Should I put a new one or use the one which came with the car.
Any suggestions please.
I have attached 2 photos.
Bali
Re: Wind screen
« Reply #1 on: September 04, 2020, 17:48:29 »
OEM (Original) wind screens were Sekurit, and always have/had the three point star on them.
Replacements do not...
Yours, aside from the rather prominent "Royal Doulton" also has the St. Gobain glass logo on it...and no logo.
If your glass is in good shape, leave it alone. Once you start driving the car--the windshield will degrade, get pitting from stones, sand, wind, etc. and then you can change it.
Jordan
  • Canada, ON, Jordan
Re: Wind screen
« Reply #2 on: September 04, 2020, 22:59:55 »
It really depends on your nut and bolt restoration.  If you are staying all original and will maybe show the car I would opt for a correct new windshield.  If not then stick with your existing windshield.
Having to replace your existing windshield later when it starts to degrade will be a bit of a head ache.  You'll need a new gasket when you do it and may damage the aluminum trim removing and reinstalling another windshield.  You might also have to remove part of the dash to get the new windshield in place.  All unnecessary if you change it now.
Marcus
66 230SL  Euro 4 speed
Re: Wind screen
« Reply #3 on: September 05, 2020, 08:25:34 »
My experience: I left the old windscreen. Then I started driving the car. Then I saw all the scratches and imperfections. So I installed a new windscreen.
doitwright
  • USA, IL, Willowbrook
Re: Wind screen
« Reply #4 on: September 05, 2020, 15:34:29 »
Label on a Pagoda windshield purchased from Tom at the Classic Center 2 years ago. I was expecting Sekurit.
Frank Koronkiewicz
Willowbrook, Illinois
balimatharu
Re: Wind screen
« Reply #5 on: September 05, 2020, 20:49:53 »
doitwrighr, Pawel66, Jordan and Mdsalemi.
Thanks very much for your comments.
I will work on this matter.
Has anyone self fitted the screen.
Is fixing the screen a specialist job or could be DIY.
Bali
Jordan
Re: Wind screen
« Reply #6 on: September 05, 2020, 21:47:32 »
Bali, if you are familiar with using a rope to install a windshield then you may be able to do it yourself.  It will require at least 2 people and patience.  I believe it has been described on other threads here so best do a search.  If you have never done it before you should get someone that has to help you.  This is what I did with another vehicle so I am more confident in doing it myself (with a second person) in future.
Marcus
Re: Wind screen
« Reply #7 on: September 05, 2020, 23:39:51 »
You may need to buy the new aluminum trim for the rubber seal at MB. I had to. Did not do it myslef.
Re: Wind screen
« Reply #8 on: September 06, 2020, 12:09:42 »
I would get a professional to do the install. They don't charge much and there's a lot at stake!
cfm65@me.com
  • Cape Town, South Africa
Re: Wind screen
« Reply #9 on: September 06, 2020, 16:13:01 »
Hi Bali,
I have done a few, it is not a big deal.
HOWEVER, I am with Cees.
Don’t attempt your first windscreen on a nuts and bolts project.
Chris
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
balimatharu
Re: Wind screen
« Reply #10 on: September 07, 2020, 11:55:27 »
Thank you all for the useful advice.
I decided to go for a new screen.
Now, where can I get a genuine Mercedes screen in UK.
Bali
Re: Wind screen
« Reply #11 on: September 07, 2020, 12:44:09 »
The MB dealer. Do not let them tell you "the car is too old, we do not have it".
They will not have not tinted, I suppose, it is not available, tinted is.
They have to go to subgroup "Heat Absorbing glass" and switch off the filters. Then you will have the PN starting with 113 for your windscreen. Could be GBP 800 or so.
You may need the rubber frame ornamental inserts as well, A 113 671 01 30 and A 113 671 02 30, if you cannot recover yours - but these you may look for outside of MB, they are expensive there. The 2 connecting clips for them are A 110 678 04 37. Rubber frame is A 113 671 02 20, I think best is to buy rubber from Mercedes.
Re: Wind screen
« Reply #12 on: September 07, 2020, 16:15:27 »
Does your insurance cover include windscreen damage?
Mine started to delaminate lower left corner and I contacted the insurer asking them if this was a “covered item” and they said yes as it impacted the structural integrity of the glass.
A new one was ordered - with sun band- and was fitted by their fitters. In whom I was initially dubious but one of their long term fitters had a Pagoda so supervised the young guns who are used to bonding new screens, not roping them in. I supplied a new MB seal
JayManek on here is in Nuneaton and will likely know an old school MB  fitter. Pm him.
« Last Edit: September 07, 2020, 16:22:02 by JamesL »
balimatharu
Re: Wind screen
« Reply #13 on: September 09, 2020, 13:07:21 »
Thanks for the replies. My car was in bits for over 2 years. So I have no insurance on it yet. Now it is time to insure it.
I have sent a message to Jay Manek.
James while I am thinking of insuring my car. Can I put this query to you as you are UK based.
I have spent over 70k till now. Plus the car was bought for 38k. How should I go about insuring it and the company will ask for the value of the car. Just a thought as you would have gone through this in your case.
 I am based in Coventry.
Bali.
balimatharu
Re: Wind screen
« Reply #14 on: September 23, 2020, 13:10:10 »
I am still on about the windscreen for my 250sl.
I was looking online for the screen and suddenly saw a new screen advertised for £ 150.00. It is green with darker green top end. Same as I am replacing.
It is a company called AGM class.
Has anyone heard of this company or dealt with this company.
It is possible to get a screen at this price.
Please some comments.
Bali.
Re: Wind screen
« Reply #15 on: September 23, 2020, 15:15:48 »
Bali
Mine is insured with PeterJames
I have an agreed value on it but that requires someone to value it - I doubt you’d get insurance on the value you have in the car but... either way you’ll need someone who knows the cars (restorer, specialist dealer, MB club etc) to attest to the value )
You’ll find the likes of Hagerty etc will have the same requirements. Mines an unlimited mileage classic policy. If you’re a member of the MB Club you may get a discount with Footman James. Though I doubt the savings would be great as the classic policy is good value (quite low risk as you look after your car)
balimatharu
Re: Wind screen
« Reply #16 on: September 23, 2020, 19:45:02 »
Thanks James.
I will look into it.
Have you any comments on the windscreen prised £150.00
A company called AGM Glass advertising at this price.
Bali
Re: Wind screen
« Reply #17 on: September 23, 2020, 20:31:37 »
None I'm afraid - and car is not handy to go look at the labels on mine
The picture above was taken at National Windscreens who supplied/fitted it
Re: Wind screen
« Reply #18 on: September 25, 2020, 13:11:09 »
Be sure to check rubber prices from MB. I ordered a soft top seal from MB without checking price. Price was over £700.00.
I had to return it and swallow a 15% handling/restocking charge.
Re: Wind screen
« Reply #19 on: September 25, 2020, 17:29:38 »
AGM appears to be a retailer, not a manufacturer. Their price is actually £120.00:
https://agmglass.co.uk/en_GB/p/windscreen-Mercedes-Benz-W113-clear-glass/325
for clear. Same price for tinted:
https://agmglass.co.uk/en_GB/p/windscreen-Mercedes-Benz-W113/304
They have, on each product link page, a place for "product inquiry" and there you can ask who is the actual manufacturer...and or any details about the product. That would a first step, or just pick up the phone and call them.
