Author Topic: Fuel lines  (Read 4310 times)
EeVeeWee
Fuel lines
« on: September 01, 2020, 19:11:57 »
I am installing the refurbished fuel pump from my 230 SL and bought new fuel and brake lines.
For underneath the bottom I made and found some usable pictures of the position of the lines and how they are connected. But at the front of the car I am not quite clear about that. Can anyone show pictures of the position of the brake and petrol lines in the engine compartment?
Thank you in advance, Eric.
« Last Edit: September 02, 2020, 06:16:58 by EeVeeWee »
Again something else.
MikeSimon
  • USA, OH, North Royalton
Re: Fuel lines
« Reply #1 on: September 07, 2020, 14:02:48 »
I can take some pictures later today, if the rain stops. In the meantime, please allow a question: Where di you buy the fuel lines? Were they pre-formed and cut?
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
sandcrab59
  • USA, MA, Lunenburg
Re: Fuel lines
« Reply #2 on: September 07, 2020, 17:20:18 »
My experience with Mercedes fuel and brake lines has been, they come in a roll and you have to unroll the roll and carefully match it to the old lines.
You might need a line bender so that you do not kink the line.
Also I have found out on my Mercedes cars is that the fuel lines for feed and return are different mm's. Be careful.
71 280SL-8  Euro
67 250 SL
72 220 D
1982 300 SD
1983 300SD
1985 300SD
1931 Model A Ford Roadster
1997 Corvette C5
Re: Fuel lines
« Reply #3 on: September 07, 2020, 17:37:12 »
Perhaps these might help you. Let me know which area you need to see.
EeVeeWee
Re: Fuel lines
« Reply #4 on: September 08, 2020, 19:07:05 »
Thank you very much!
The next question is how are the brackets mounted?  :o
There are holes reachable from above the floor but some are in a closed compartment.
So what kind of bolts are used for these brackets?
EeVeeWee
Re: Fuel lines
« Reply #5 on: September 08, 2020, 20:24:31 »
I found these bolts before, but you still must be able to reach the holes from the upper side which is not everywhere possible.
And not every hole is square.
Or am I missing something?
Re: Fuel lines
« Reply #6 on: September 12, 2020, 08:27:23 »
Some of them use hex headed sheet metal screws where the bracket falls into a boxed section.
If you are making your own flares do the flares for the engine ends before you install the lines.  From experience trying to get enough torque the flare a 10mm line next to the frame and engine really sucks.
« Last Edit: September 12, 2020, 08:41:55 by Shvegel »
Re: Fuel lines
« Reply #7 on: September 12, 2020, 08:56:58 »
From the parts list I see:
N 000085 006124 SCREW Replaced with N 007985 006133
then
N 007985 006133 SCREW FUEL AND BRAKE LINES TO FRAME FLOOR UNIT 3pcs
I also see
A 120 420 02 27 SCREW W RECTANGULAR HEAD FUEL AND BRAKE LINES TO FRAME FLOOR UNIT 1 pc (this is the one shown in post below)
And I got a bit confused as 1 of those latter ones is needed for fuel pump bracket to trunk floor fixing. This would suggest that this 1 piece from parts list is for fuel pump rather than the fuel lines. But I am not sure if this is true.
I see just tapping screws in the parts list for the front support fuel line fixing.
Re: Fuel lines
« Reply #8 on: September 16, 2020, 13:36:40 »
These may help
« Last Edit: September 16, 2020, 14:06:36 by Naj »
Re: Fuel lines
« Reply #9 on: September 16, 2020, 14:09:06 »
Couple more
EeVeeWee
Re: Fuel lines
« Reply #10 on: September 16, 2020, 14:27:27 »
I am very happy with these pics, thank you very much!
sandcrab59
Re: Fuel lines
« Reply #11 on: September 20, 2020, 11:19:19 »
Great Pictures NAJ.
Is that your car?
Hope you are feeling Good.
Tom M
71 280SL-8  Euro
67 250 SL
72 220 D
1982 300 SD
1983 300SD
1985 300SD
1997 Corvette C5
Leester
  • USA, VA, Lorton
Re: Fuel lines
« Reply #12 on: September 20, 2020, 16:15:59 »
My thanks to you, Naj, as well. I am in the midst of doing these brake, fuel lines and brackets myself. Photos at Motoring Investments were helpful but yours are much better. Thanks again. Lee
Lee Backus
1963 220SE Cabriolet
Re: Fuel lines
« Reply #13 on: September 21, 2020, 10:53:55 »
Great Pictures NAJ.
Is that your car?
Tom M
I.m good, Thanks, Tom
The dirty one may be my 230, Not sure
The blue one was on a ramp on the Mechatronic stand at TechnoClassica at Essen in 2009.
