Author Topic: Which is the manual transmission fill port?  (Read 2733 times)
rbouch8828
  • USA, MA, Framingham
  • 280SL Mfg date AUG 1969
« on: August 03, 2020, 16:10:38 »
This picture shows the right side of the manual transmission looking up from the bottom. You may have to click on the photo and scan to the right to see it all.
Can someone tell me which one is the filler port?
RB
RB
cfm65@me.com
  • Cape Town, South Africa
Re: Which is the manual transmission fill port?
« Reply #1 on: August 03, 2020, 19:17:31 »
RB,
The big allen screws are normally the drain and refill ports. The bottom one is obviously the drain and the one halfway up the side, as in your photo, is the refill hole.
Chris
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
rbouch8828
« Reply #2 on: August 03, 2020, 19:48:03 »
RB,
Chris
Hi Chris,
Wonderful!
Thanks for the clarification!
RB
RB
cfm65@me.com
« Reply #3 on: August 03, 2020, 20:46:39 »
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
« Reply #4 on: August 04, 2020, 14:40:22 »
As a tip, always remove the fill port first to make sure it is not stuck/frozen. Could be a bit of an issue if you drain the tranny and then find out there is an issue with the fill port (same for the differential).
JN
  • USA, NJ, egg harbor twp
« Reply #5 on: August 04, 2020, 15:22:40 »
Great Tip
JN
1967 250 SL Coupe
2014 GLK 250 BlueTec
1994 Ford F 150 4wd
