Please check out joining the
Emergency Contact List
for help during your travels!
Electrical and Instruments
Bizarre auxiliary fuse box
Topic: Bizarre auxiliary fuse box (Read 3650 times)
col320ce
Full Member
Gold
Australia, Victoria, Glen Iris
June 21, 2020, 12:42:23 »
Both channels are linked... Seems odd to do this. I wanted to use it as a constant and switched ignition aux power supply. I assumed there was some metal caught behind it.
Col
1964 230SL
1965 250SE coupe
1993 320CE Sportline
WRe
Full Member
Platinum
Germany, Hessen, Seeheim-Jugenheim
Re: Bizarre auxiliary fuse box
June 21, 2020, 12:47:30 »
it looks correct, dirty only, see new one here:
https://www.oldtimerbedarf.de/Sicherungsdose-2-polig-inkl-8A-Sicherungen-schwarz-30x45mm
...WRe
col320ce
Full Member
Gold
Reply #2 on:
June 21, 2020, 12:55:33 »
If you look underneath the new one the poles aren't connected whereas they are on mine...
Col
1964 230SL
1965 250SE coupe
WRe
Full Member
Platinum
Reply #3 on:
June 21, 2020, 13:32:59 »
Indeed, I see , looks strange, maybe special usage.
Full Member
Platinum
Poland, Mazowieckie, Konstancin-Jeziorna
Reply #4 on:
June 21, 2020, 15:11:21 »
Is only one side connected or both sides?
If one side only - one power source to two circuits. Would work maybe for fog lights, left and right.
col320ce
Full Member
Gold
Reply #5 on:
June 22, 2020, 05:08:05 »
Only one side...
Col
1964 230SL
1965 250SE coupe
Desertpagoda
Associate Member
Silver
USA, AZ, Tucson
Reply #6 on:
July 31, 2020, 01:20:42 »
common, would work most anywhere. 1source 2 feeds
kb
Full Member
Platinum
USA, OH, Blacklick
Reply #7 on:
August 15, 2020, 14:13:17 »
It is common to find these connected in this way. However, I believe they are made both ways. One version with a common power source and the other version isolated.
col320ce
Full Member
Gold
Reply #8 on:
August 16, 2020, 02:16:29 »
It definitely flummoxed me for a bit as I has just renewed the wiring harness and put this in at the same time with both a permanent and ignition switched input. This resulted in the switched ignition curcuit being live as soon as I connected the battery. Unfortunately I pulled the instrument cluster out thinking that I had made a mistake there.
I'll get one with 2 channels in and 2 out as I want the radio to turn off with the ignition but I have an auto aerial. All to be installed soon!
Thanks for all the comments
Col
1964 230SL
1965 250SE coupe
