Author Topic: Numberplate wiring connection  (Read 4179 times)
col320ce
« on: May 31, 2020, 11:47:31 »
How does the number plate wiring connect to the wiring harness.  Mine was soldered (badly) onto the L brake light wiring ... I'm assume it should clip in somehow around here? (w111 250SE coupe)
Thanks!!
Col
1964 230SL
1965 250SE coupe
1993 320CE Sportline
Re: Numberplate wiring connection
« Reply #1 on: May 31, 2020, 13:02:08 »
I assume the connection w113 is not much different from w111.
See below.
col320ce
« Reply #2 on: May 31, 2020, 13:08:59 »
I was more specially trying to understand how it physically attaches... ie the plug arrangement...
Col
1964 230SL
1965 250SE coupe
« Reply #3 on: May 31, 2020, 13:23:00 »
I made this critical effort, moved from the sofa and went to the garage to take the picture...
Ignore the additional wire coming out of the grommet - this is for fog lamp, I htink.
You see the plug in the lamp housing. The same plug is on the other side.
Grommet: A 113 997 03 81
The plug is not listed separately in the spare parts list, there is just the lamp with plug and wire:
A 113 820 00 62
No idea why picture attached upside down... sorry.
col320ce
« Reply #4 on: May 31, 2020, 13:34:43 »
Thanks Pawel for getting off your couch!
That's perfect; I can now see how it goes.
Col
1964 230SL
1965 250SE coupe
« Reply #5 on: May 31, 2020, 14:48:24 »
Will try to identify this plug...
« Reply #6 on: May 31, 2020, 14:53:36 »
I think it is this one, form our Tech Manual:
K9602
 009 545 44 28      plug housing
 009 545 45 28      cover
 001 545 37 28      pin contacts
« Reply #7 on: May 31, 2020, 20:27:46 »
I have a 280SL 1969, the connection is completely different.
From which MB is this photo?
« Reply #8 on: May 31, 2020, 22:21:12 »
I am sorry! I missed you are talking W111!
This is from March 1970 280SL Euro.
My apologies....
« Last Edit: May 31, 2020, 22:25:13 by Pawel66 »
