Author Topic: Soft Top Springs  (Read 3346 times)
Soft Top Springs
« on: March 17, 2005, 10:17:25 »
I am missing both of the large soft top springs.  K&K sells them at $32.00 each.  Does anyone know an alternative source for these springs, hopefully at a lower cost.  Seems a bit high for springs...
Memphis, TN.
1997 E320
Re: Soft Top Springs
« Reply #1 on: March 17, 2005, 10:38:49 »
Memphis, TN.
1997 E320
Gee, when anything is less then $50 I'm happy...but that's just me.  My car is in storage else I'd help; but find the dimensions of the springs and you can probably find something off the shelf that might work.  Try http://www.springsfast.com or http://www.allrite.com/index.html or http://www.generalwirespring.com/  Once you have some idea of dimensions you should be able to source them alternatively.
« Reply #2 on: March 17, 2005, 12:29:26 »
Hi Mike,
I know....  $64 bucks is small change compared to the $1,000's already spent on our cars...  just seems a lot for springs.
Can someone please take a picture of the correct OEM soft top spring and post it.  Also, post the measurement(the length and diameter)...?
Thanks!!!
Memphis, TN.
1997 E320
« Reply #3 on: March 17, 2005, 17:01:54 »
So you're saying you don't want to "spring" for the factory parts?
I bought a factory set for my last SL and bit the bullet. I'll tell you this -- those suckers are subjected to a lot of tension. For me, the extra $20 or $30 was worth it knowing they're up to the task.
