Author Topic: grease cap removal tool  (Read 4818 times)
« on: March 15, 2005, 12:40:57 »
I just received the latest issue of the Star Magazine and in the technical column written by George Murphy there is a question as to removing the front wheel bearing grease caps. George mentions that there a specific tool that graps the caps on the rolled edge designed for pulling and pushing the cap.
I talked with George Murphy Technical director of the Mercedes-Benz club America. Geroge said carfully using a flat screw driver will remove the cup and to reinstall he recommended going to home depo plumming department and getting a peice of PVC that fits down over the club and flang and tapping it in place with a peice of wood.
sounds like a plan.
« Last Edit: March 16, 2005, 12:07:43 by Bob G »
erickmarciano
  • Canada, Quebec, montreal
Re: grease cap removal tool
« Reply #1 on: March 15, 2005, 14:14:19 »
a plumber wrench will do
1971 280sl
1962 VW
1954 Allstate vespa
1958 gs150 vespa
1962 gs160 vespa
1994 E500 W124
1971 280sl
1989 Porsche 930 coupe
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
Vince Canepa
« Reply #2 on: March 16, 2005, 14:04:01 »
A bearing separator and a slide hammer will work nicely to remove the caps. The PVC pipe trick works great for driving them back on.
Vince Canepa
113.043-10-001543
568H Signal Red
116 Caviar MB-Tex
« Reply #3 on: March 16, 2005, 16:51:25 »
Nah, too complicated. I just use a big hammer and pound it off.
 Actually, if you screw one of the lug crews back in and use a hooked wrench it will pop right off.
