Author Topic: door strap parts w111  (Read 3622 times)
col320ce
« on: May 12, 2020, 03:05:34 »
I'm missing a few parts on the door strap.  I have the rubber but it looks like there is supposed to be a plastic plate behind this.  Is it all held together with a split pin (that's how the other door is done)?
It's also missing the nylon roller ... is this a separate part or do I need to order the whole assembly ( 111 720 50 43  )
Thanks!
Col
1964 230SL
1965 250SE coupe
1993 320CE Sportline
Aaron h
Re: door strap parts w111
« Reply #1 on: May 12, 2020, 04:18:20 »
The nylon roller comes with the plate it's housed in.  As far as the other pieces you're after you'll have to be more detailed as to what you're asking about.  Picture below.
col320ce
« Reply #2 on: May 12, 2020, 04:24:50 »
Hi Aaron
I have the new rubber 263 and I'm missing 269. How are these held in place?
Col
1964 230SL
1965 250SE coupe
SwedenBens
  • Sweden, Västra Götaland, Alingsås
« Reply #3 on: May 24, 2020, 10:02:31 »
269 are just a metal plate that the rubber will be presst to when door is fully opened,the metal plate are loct whith a cotter pin behind
col320ce
« Reply #4 on: May 24, 2020, 13:39:27 »
Thanks!
I made a metal plate last week so I'll sort the pin out tomorrow.
Col
1964 230SL
1965 250SE coupe
