Author Topic: US spec vs. Euro spec 280  (Read 3162 times)
« on: March 15, 2005, 08:26:48 »
Hi!
Just trying to cross reference some information I've picked up in a book (The Mercedes-Benz since 1945, Vol 2 by James Taylor) regarding US-spec 280 SLs and was wondering if anyone can verify what he says.
Basically he lists post '68 detox cars as having 'revised fuel injection' ,  a milder camshaft with less overlap,  beefed-up cooling system and a lower axle ratio of 4.08:1 to compensate for the 10hp reduction in output.
I'm interested having just driven a Californian-spec 1970 280 SL and it felt pretty good but if Euro-spec cars are a bit spicier then it would be useful to know!
Any further info would be gratefully received!  :)
Re: US spec vs. Euro spec 280
« Reply #1 on: March 15, 2005, 09:49:45 »
Merc,
the US spec engines make about 10 hp less than the Euro engines.  The differences are a milder cam and differently calibrated injection pumps.  The 1970/71 US cars also use different distributors, but the advance curves appear to be pretty similar.  Final drive gearing is also different, with the earlier Euro 280 SL's having 3.92 diffs while the US cars got 4.08's.  Round about late 1969 or early 1970 production (maybe at the model year break point?) the Euro diffs went to 3.69 and the US diffs went to 3.92.  The gear ratios aren't hard and fast because there were optional ratios available for a while, but in the US optional ratios were unavailable for the last year or two.
There are also a number of cosmetic differences, like hard door pockets in the Euros vs soft pockets for the US, plus several more things.
Unfortunately, the Euro cars also tend to suffer from rust problems more than the US cars because of the use of salt on the roads.
