Author Topic: Locking Gas cap  (Read 3585 times)
behnamlaw
Locking Gas cap
« on: May 08, 2020, 20:00:48 »
Hello. Is there a way to re-key my gas cap to match fit my ignition key?
mbzse
Re: Locking Gas cap
« Reply #1 on: May 08, 2020, 20:50:21 »
There is a fine description of the Pagoda gas cap in the Tech Manual (Wiki).
Re-keying is mentioned. This can be the same key as ignition, but only on late 280 SL cars.
You have access since you are Full Member.   Look under Fuel system, section
Fuel tank and Locking gas cap
« Last Edit: May 09, 2020, 15:32:08 by mbzse »
/Hans S
behnamlaw
Re: Locking Gas cap
« Reply #2 on: May 08, 2020, 20:51:15 »
many thanks
Re: Locking Gas cap
« Reply #3 on: May 11, 2020, 22:48:50 »
Quote
Hello Nameless,
Impressive array of car collection you have...
Eight wonderful cars and one not so...
Well, from your cars, you might now that some (until 1969) have got three keys according to the datacard before the one-key-un/locks-it all came in.
On the earlier system where the door key also locks/unocks the gas cap (parts number A000 471 2030), re-keying is usually no problem,
but on the late system (A000 471 4730) it is ...
because the main problem is you cannot currently get such a gascap
and second they are not easy to be opened.
First of all you need a late-style (on key for all) gas cap.
Good luck,
behnamlaw
Re: Locking Gas cap
« Reply #4 on: May 11, 2020, 23:15:01 »
Thanks Achim
I know which model you are referring to but its been a wonderful family car "thus far" :)
My 180G 280 113 has the 3 key system
1. Ignition key
2. Door key
3. Trunk key but non will operate the gas cap lock so I am assuming its not the original gas cap or lock mechanism has failed
The 050 280 has a one key system as you mentioned but gas cap has no lock
Ebay has a host of them used from $120 to $365 new
Thanks for the part #
Saman
Rolf-Dieter ✝︎
  • Canada, ON, London
Re: Locking Gas cap
« Reply #5 on: July 01, 2020, 17:12:52 »
Hi Saman, You can add your First Name to the "Signature Field" Check it out here;
----> https://www.sl113.org/forums/index.php?topic=31309.msg227118#msg227118
Dieter
behnamlaw
Re: Locking Gas cap
« Reply #6 on: July 01, 2020, 18:17:40 »
Hi Rolf-Dieter:
Thanks for the tip
Saman
John Betsch - "SADIE"
  • USA, NY, SOUTHOLD
Re: Locking Gas cap
« Reply #7 on: July 01, 2020, 18:29:50 »
Here is a way-out possibility.  On my gas cap/key (which are original) if the key doesn't work when inserted,  I take it out and then insert  facing in the opposite direction and it works.  (I have the three key system)
jb
doitwright
  • USA, IL, Willowbrook
Re: Locking Gas cap
« Reply #8 on: July 01, 2020, 20:10:41 »
Have you considered taking the cap to a locksmith?
Frank Koronkiewicz
Willowbrook, Illinois
