Author Topic: Fitting the viscous coupling  (Read 2529 times)
« on: May 06, 2020, 16:48:47 »
As many of you will know, fitting the four bolts that secure the viscous coupling is a PITA.
Here's a little trick that makes it a whole lot easier!
https://www.youtube.com/watch?v=R2W2srGd7pU
Re: Fitting the viscous coupling
« Reply #1 on: May 06, 2020, 17:03:25 »
Wow! This is cooool!
Thank God you have not started the car this way!
You absolutely need some identity there.
johnk
  • USA, OH, Avon
« Reply #2 on: May 07, 2020, 01:30:59 »
Thanks Stick. This will save me a lot of aggravation in the next week or so. I am always amazed at the common sense solutions that successful mechanics are able to come up with quickly.
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
« Reply #3 on: May 07, 2020, 11:35:40 »
It took me 40 years to think of it so not sure "quickly" is appropriate!  :D
doitwright
  • USA, IL, Willowbrook
« Reply #4 on: May 07, 2020, 14:46:19 »
Brilliant! Just like starting a lawn mower.
Frank Koronkiewicz
Willowbrook, Illinois
« Reply #5 on: May 07, 2020, 17:03:14 »
Safety: do not attempt to look at the screw and rubber band from close distance from above while doing this.
