Author Topic: Distributor Grease  (Read 3300 times)
col320ce
Distributor Grease
« on: May 06, 2020, 06:35:39 »
Has anyone got a replacement recommendation for the now obsolete bosch 5-700-002-025 Ft1v4 grease?
Thanks!
Col
1964 230SL
1965 250SE coupe
1993 320CE Sportline
And George, the infamous 1992 Ford Laser
Aaron h
Re: Distributor Grease
« Reply #1 on: May 06, 2020, 12:05:56 »
I'm certain there are other alternatives out there.  But if you want the actual Bosch grease you'll have to buy it in small quantities.
https://www.allzim.com/store/bosch-distributor-grease-2g-packet.html
« Reply #2 on: May 06, 2020, 14:46:25 »
A small tube of this stuff will last you a lifetime.
« Reply #3 on: May 06, 2020, 16:00:02 »
My tube of Bosch lube has been in my toolbox 30 years.
“Standard Lubricam”is probably a good substitute.  Standard Ignition has been around forever as well.
behnamlaw
« Reply #4 on: May 06, 2020, 17:51:19 »
Hey Aaron
Hope your well
Just looked  at a 600.
I will text you later
Saman
col320ce
« Reply #5 on: May 07, 2020, 21:13:59 »
Thanks everyone!
Col
1964 230SL
1965 250SE coupe
wayne R
« Reply #6 on: May 08, 2020, 02:50:41 »
Sorry about photo , not to clear,
Dielectric tune up grease,  by permatex, been in my tool kit from 1991
USA,----Hey Col  its available from Autobarn, parts store here in Queensland,
they should have it  in your City.----if you can not get any let me know i could send you
up a tube  regards..
col320ce
« Reply #7 on: May 10, 2020, 12:46:33 »
Thanks for the tip Wayne... The permatex is available locally. All the other recommendations are not so easy to get in Australia.
Col
1964 230SL
1965 250SE coupe
