Author Topic: Rear axcle / trailing arm rebuild  (Read 2576 times)
dirkbalter
  • USA, CA, Corona
« on: May 02, 2020, 17:08:16 »
Hello all,
As part of my rear axle rebuild, I intend to rebuild the tailing arm bushings. The BBB shows the washer, item # 6, held in place with a retaining ring item # 3.
Looking at my trailing arm, I don’t see a retaining ring. It appears that the washer is welded instead.
I searched around in the forum but couldn’t find anything.
What am I missing? Can someone comment on this or point me in the right direction?
Thank you much
« Last Edit: May 02, 2020, 17:12:28 by dirkbalter »
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
dirkbalter
  • USA, CA, Corona
Re: Rear axcle / trailing arm rebuild
« Reply #1 on: May 02, 2020, 17:09:44 »
another pic
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
« Reply #2 on: May 02, 2020, 18:08:14 »
The "Weld" you are seeing is actually the retaining ring.  It started out round and corroded down to a fillet.  If you look carefully you will see a break in the fillet somewhere.  You need to compress the "Washers" in order to get the retainer out.  I used a couple short pieces of pipe that fit over the center bushing.  I cut a U shaped notch on one pipe so I could reach in and pick the retainer out.  Put the whole mess in a vice and squeezed it down.  This has been posted on before so do a search for "Control Arm" and you should find at least one picture of this.
mbzse
« Reply #3 on: May 02, 2020, 18:27:33 »
Quote from: dirkbalter
.../...Can someone comment on this or point me in the right direction?
Some useful info for instance in this Forum posting:
https://www.sl113.org/forums/index.php?topic=11244.msg137500#msg137500
/Hans S
Sead
  • Bosnia and Herzegovina, Federation of Bosnia and Herzegovina, Sarajevo
« Reply #4 on: May 02, 2020, 19:27:57 »
here..
1964 230SL
dirkbalter
  • USA, CA, Corona
« Reply #5 on: May 02, 2020, 20:54:22 »
Much appreciated everyone. @ Shvegel - That's exactly what it was. Just looked to much like a weld beat to me.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
Aaron h
« Reply #6 on: May 02, 2020, 22:22:53 »
Sead, it may or may not matter so much to you or others, but all of the hardware in this area is supposed to be black zinc oxide coated, not yellow zinc chromate.
« Last Edit: May 03, 2020, 08:56:14 by Aaron h »
Sead
« Reply #7 on: May 03, 2020, 05:55:54 »
Sead, it may or may not matter to you or others, but all of the hardware in this area is supposed to be black zinc oxide coated, not yellow zinc chromate.
Thats interesting detail i did not know about...!
Thx
1964 230SL
