Author Topic: Exhaust Manifold Stud Hardware  (Read 6821 times)
W14
« on: May 09, 2003, 13:33:26 »
Hello All,
I am just about to re-install the exhaust and intake manifolds to the head.  Should there be washers between the stud nuts and the manifolds?
Mine just has the nuts, which doesn't seem correct, especially for these "split" manifolds.
Will W14
1965 230SL 4spd
Victoria,BC
Re: Exhaust Manifold Stud Hardware
« Reply #1 on: May 09, 2003, 14:08:04 »
On my 1969 280 SL there are washers there. I would not dream of NOT using good quality washers. These manifolds are pretty expensive to replace, and they can break. Also watch for the connection between the manifolds and the exhaust downpipes - overtightening these can also cause breakage.
W14
« Reply #2 on: May 09, 2003, 23:31:41 »
Ok, thanks Cees - I'll rustle up some washers!
Will W14
1965 230SL 4spd
Victoria,BC
« Reply #3 on: May 10, 2003, 02:42:38 »
Will,
Go for the original washers and nuts.
I think the washers are quite hard and of course the right outer diameter and the nuts are copper coated.
Sorry part numbers not to hand
hobel 65 230SL
jalopyno 68 280SL
W14
« Reply #4 on: May 10, 2003, 22:38:22 »
Thanks Naj, I'll check to see what the local MB dealer has.
Will W14
1965 230SL 4spd
Victoria,BC
« Reply #5 on: May 11, 2003, 05:35:41 »
Will,
Part #s:
N 000125 010532     washer
N 000137 010201     spring washer
A 000 990 3150      nut
happy fitting
hobel 65 230SL
jalopyno 68 280SL
W14
« Reply #6 on: May 11, 2003, 11:06:33 »
Thanks Naj!
I didn't know about the spring-washers.
Will W14
1965 230SL 4spd
Victoria,BC
