Author Topic: Can this seat problem be fixed with a pool noodle?  (Read 3055 times)
GM
  • USA, CO, Boulder
« on: April 25, 2020, 18:53:24 »
Hi all,
I need to fix a “dimple” in my driver’s seat (see photos).
The seats are in excellent condition otherwise, so can the pool noodle insert fix this dimple problem, or do I need to do something different? I wasn't able to find a comparable situation in reviewing the posts on pool noodles.
Thanks!
Gary
Gary
1971 280SL - Sold
DB180 Silver Gray Metallic
Black MB Tex
Re: Can this seat problem be fixed with a pool noodle?
« Reply #1 on: April 25, 2020, 19:45:29 »
Not sure that’s a pool noodle problem
mrfatboy
  • USA, CA, Rancho Santa Fe
    • Mrfatboy
« Reply #2 on: April 25, 2020, 20:42:38 »
That's a pad problem. You might be able to stuff in some very high density foam to take out the dent.  You will just have to experiment.   Or buy a new pad.
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
« Reply #3 on: April 25, 2020, 23:30:09 »
I don’t think that a pool noodle will fix that but i would maybe take out seat and try to stuff foam into the problem area then fix in a pool noodle as per photos to hold it in place.
« Reply #4 on: April 26, 2020, 00:55:33 »
Carpet padding in the flutes was one upholsters solution.
mrfatboy
    • Mrfatboy
« Reply #5 on: April 26, 2020, 01:08:41 »
For reference here is a pic of one of the seat cushions that I pulled out when I redid them. As you can see someone was in there before and added foam to bolster the sides.
I ended up spending the money and buying new pads for both seats.  My butt thanks me🤣
Signal Red
4 Speed
GM
  • USA, CO, Boulder
« Reply #6 on: April 26, 2020, 15:57:08 »
Thank you all for your help and suggestions!
Gary
1971 280SL - Sold
Black MB Tex
