Author Topic: Recommended Source For Trunk Floor Patch Panels  (Read 3029 times)
Chris Long
  • USA, NJ, Morristown
« on: April 19, 2020, 21:22:51 »
Any suggestions or recommendations on trunk floor panels.
I think I will need main floor and left and right sides.
K and K seem pretty reasonable...
1970 280sl 4-Speed Horizon Blue
Re: Recommended Source For Trunk Floor Patch Panels
« Reply #1 on: April 19, 2020, 23:02:38 »
You may want to also look here
https://www.sl113.org/wiki/Suppliers/Warsaw
johnk
  • USA, OH, Avon
« Reply #2 on: April 20, 2020, 03:20:12 »
I bought mine from K&k and they worked fine. Would buy from them again.
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
« Reply #3 on: April 20, 2020, 04:00:06 »
Yes, K&K is a good choice. In fact, their panels are arguably better than original since they are zinc coated on both sides making them more corrosion resistant than the originals. K&K was making and selling 190SL replacement floor panels directly to Mercedes-Benz as an OEM supplier some years back. They have a nice website and on-line parts catalogs which are very helpful.
johnk
  • USA, OH, Avon
« Reply #4 on: April 21, 2020, 01:06:48 »
Another option to consider if you main panel is only rusted by the seam is to just replace the foot or so on the left side.  It’s probably a day or two less work and you are retaining the integrity of most of the original panel. I’m not that efficient with replacing metal but it only took me a day to replace that section including welding the replacement panel in with faux spot welds. You have to buy the full panel and will not use 3/4’s of it but it’s a nice piece of sheet metal to have  around.
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
Chris Long
« Reply #5 on: April 21, 2020, 12:51:56 »
Left side has some but it looks like water tracked along the electrical cord. Holes are actually on the right under where the wire goes to rear right light cluster. Seems like best strategy is do it once and do it all...
Delvis
  • Canada, British Columbia, Delta
« Reply #6 on: April 22, 2020, 04:26:12 »
Hi, replaced the trunk floor in 1971 280SL, bought items directly from local Mercedes Benz service/parts counter. was my 2017 project - perfect fitment.
113-616-02-62 - trunk floor
113-610-08-62 - floor -trunk right
113-611-00-03 - floor floor - left
hope this helps
Devlin
1970 280SL auto.
1989 560SL
1979 911 SC TARGA
1961 Dune Buggy
2015C63 507 Edition
