Author Topic: Power Steering Hose part#  (Read 3682 times)
col320ce
« on: April 18, 2020, 03:42:59 »
Can anyone identify the power steering part number for the red hose below the power steering oil reservoir in the photo?  W111 250SE coupe 1965.
Thanks!
Col
1964 230SL
1965 250SE coupe
1993 320CE Sportline
Re: Power Steering Hose part#
« Reply #1 on: April 18, 2020, 09:25:57 »
For 111.021 from chassis 08538, the hose reservoir to pump is A 006 997 09 82, sold by meters. It is not any elbow shaped in case you thought it might be.
Before chassis 08538 I do not have power steering parts in parts list.
col320ce
« Reply #2 on: April 19, 2020, 10:33:45 »
Thanks, that is perfect!
I'll get some and try it as there is a good chance that it will fit.  I don't like the look of the kink in the one on my car ...
Col
1964 230SL
1965 250SE coupe
« Reply #3 on: April 19, 2020, 15:46:58 »
They make a spring that fits inside a hose like this to prevent collapsing. If you are using an MB hose with a part number, the material should be ok. Auto trans fluid is hard on materials and you want to use a hose material that is made for that.
specracer
  • USA, MA, Duxbury
« Reply #4 on: April 19, 2020, 22:42:34 »
I replaced this hose last week. someone had done it before, and it was rubbing the battery tray, wore through. I was able to tweak the reservoir (it was too low), and get a natural bend (with out a kink).
