Author Topic: Under Dash Panels RHD W111  (Read 4366 times)
col320ce
« on: April 16, 2020, 22:48:37 »
Does anyone know where I can get these from or a pdf cutout so I can make my own?
Thanks very much!
Col
1964 230SL
1965 250SE coupe
1993 320CE Sportline
Re: Under Dash Panels RHD W111
« Reply #1 on: April 17, 2020, 12:23:58 »
I used my old ones as a template. Pagoda but a 111 shouldn’t be inherently different
Got the board from (likely) SLS, bought some glue backed foam and made my own. I’m Ham-fisted in the extreme but they fit, stay in place and look better than before
mrfatboy
  • USA, CA, Rancho Santa Fe
    • Mrfatboy
« Reply #2 on: April 17, 2020, 12:31:34 »
The under dash PDF templates for a LHD Pagoda are in the techical manual if that helps as a starting place.
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
Aaron h
« Reply #3 on: April 17, 2020, 13:06:56 »
For RHD 250se coupe`/cabriolet, the original part number for the right side under dash cover was 111-680-65-17, but was changed to 000-983-22-91, which is a square meter of the actual material the original was made from.  So for this one you'd need a template or original to go from.  The material is still available.
For the left side under dash cover, the original part number for a RHD car was 111-680-56-17, but it too was changed to the 000-983-22-91.  So again, you can get the material, but you'll have to have a template or an original to go by.
The pieces for LHD cars are still available new, and I want to say that the pieces for the RHD models could very well be inverses of the LHD pieces.  If so, then you may be able to buy the LHD model pieces and use them as a template but the inverse of.  Also, if you have air conditioning the left hand piece will have to be further modified, but only after the original shape is cut out.
col320ce
« Reply #4 on: April 17, 2020, 13:30:53 »
Thanks for that.  I assume too that the RHD is similar to an inverse of the LHD but it will be an expensive thing buying them to make my own template.  I might make some rough sketches from photos on the net and make something functional.   Unfortunately they are quite different from the pagoda shapes... which I also need to get/make at some point too.
Col
1964 230SL
1965 250SE coupe
« Reply #5 on: April 17, 2020, 20:01:59 »
You can ask these guys maybe, when they are back from holidays:
https://www.cbs-autoteile.de/interieur/mercedes/heckflosse-w110-w111-w112.html?p=1
col320ce
« Reply #6 on: April 17, 2020, 22:33:44 »
I've sent him an email ... thanks for the tip.
Col
1964 230SL
1965 250SE coupe
behnamlaw
« Reply #7 on: June 01, 2020, 21:16:35 »
I had these made at the shop and covered with the leftover carpet.
