Author Topic: steering box  (Read 4885 times)
mauro12
  • Italy, Sicily, Messina
steering box
« on: March 31, 2020, 09:58:13 »
hello guys, during this hard time I decided to spend more in garage. I've noticed a small leak from my steering box, I have to say that the steering wheel fells tight and without play so far, but I wanted to know if this leak can be fixed only with new seals or maybe it is worth to overhaul. What do you think? what can be the cost of an overhaul of the box? thank you
Mauro Pisani
250sl 1967 5speed zf manual
Re: steering box
« Reply #1 on: March 31, 2020, 12:34:01 »
Power steering? If it is just a leak from the top, even I was able to fix it, based on these instructions: https://www.sl113.org/wiki/Steering/PowerSteeringBox
mauro12
Re: steering box
« Reply #2 on: March 31, 2020, 14:37:56 »
No it is not from the power steering but from the steering box. I see some drops coming on the floor and also when you look from the hood of the car it is quite oily the box.
Mauro Pisani
MikeSimon
  • USA, OH, North Royalton
Re: steering box
« Reply #3 on: March 31, 2020, 14:54:11 »
The seal that is most likely to leak in a power steering gear (box) is the seal for the input shaft. Both heat and pressure will wear this out. I am not sure if you will achieve much with an "overhaul" .
Other than paying someone money for basically nothing. Replacing the seal is the only service a gear will need, other than a flushing job, which you will do anyway when the seal is replaced.
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
Re: steering box
« Reply #4 on: March 31, 2020, 17:01:42 »
I meant steering box with power steering.
yves
  • France, Poitou-Charentes
Re: steering box
« Reply #5 on: March 31, 2020, 17:06:32 »
Hi Mauro , i have done that job some months ago with no particular skill but i have specificaly followed the instructions from the forum manual . You must follow the torque rules of each bolt  . Y'll have the link below:
https://www.sl113.org/forums/index.php?topic=29637.0
And keep cool even if you have some issues... ;)
Aaron h
Re: steering box
« Reply #6 on: April 01, 2020, 03:38:25 »
In the picture below, note the two highlighted parts.  The cylindrical valve has 5 o-rings that go around it, and are internal to the gear box.  These o-rings are notorious for getting hard and leaking.  The leak will come from the weep hole on the bottom of the lower sector shaft cover plate.  When this happens there is no way around removing the gear box and disassembling it.
If the outer sector shaft radial seals are leaking those can sometimes be replaced in situ, but can prove to be difficult.  If the worm gear shaft radial seals are leaking (where the steering wheel shaft connects to the gear box) that will also require removal of the gear box.
The top of the gear box where the pre-load for the power piston to sector shaft is set has one o-ring around the metal disc and two copper crush washer between the nuts.  This area can also be repaired in situ.
Bear in mind that replacing a few seals will usually cause the other old seals to start leaking, and that it may be worth taking the gear box out and re-sealing the whole thing.
Regarding seal kits.....Meyle and FEBI make kits, but I've had some problems with them not including all of the necessary seals in the kit.  I've also experienced failed seals in 2-5 years time.  I don't know what they're using to make their seals with, but it's apparently inferior to whatever Mercedes uses.  That's where the catch is though.  Far too many customers refuse to pay the price of the Mercedes kit, so I'm left with having to use aftermarket.  The trade off is whether you want the re-sealed gear box to be leak free for another 15-20 years or 2-5 years.
Currently, the seal kit from Mercedes retails for $248 and wholesales for around $180.  Aftermarket kits range anywhere from $30-$60.  I understand wanting to save money, but given the aggravations in removing  and re-installing the gear box I'd fork out the money for the Mercedes kit.
Beware of sellers offering rebuilt gear boxes online.  Many don't take the whole box apart, and if they do they have no idea how to reset the pre-load.  So you end up with a gear box that has too much play in it or is too sensitive.  On top of all of that, they all like to charge a small fortune for them.
In essence, your gear box likely needs nothing more than a re-seal.  Internal parts rarely, if ever, wear to any notable degree.  However, you'll be better off long term removing the gear box and having the whole thing re-sealed.  If you remove/install the box yourself, then make sure you:
1) know how to center the gear box and steering wheel for reassembly,
2) that you have the centering tool or some homemade equivalent
3) Renew the steering coupling/coupling bushings for between the gear box and steering wheel shaft.....never a better time than when the gear box is out.
awolff280sl
  • USA, FL, Sarasota
Re: steering box
« Reply #7 on: April 01, 2020, 12:05:12 »
Pierre Hedary gave me this tip:
I had a minor steering box leak, damp and with only the occasional droplet on the floor.
Pierre suggested that I put 2-3 fluid ounces of K&W TransX 75K automatic transmission treatment in my PS reservoir. Normally I don't go for additives, but within 2 weeks the box was dry.
This TranX stuff is thin, not gooey or gummy. I don't know yet if I will leave it in or flush it out eventually, but it seems to have worked for my relatively minor leak.
Andy   Sarasota, FL
'69 280SL 4speed
'06 Mitsubishi Evo
Re: steering box
« Reply #8 on: April 01, 2020, 14:36:13 »
I had this problem on several boxes and found that switching to synthetic fluid instead of dexron 2 solved the issue.
I also concur that most vendors claiming to rebuild these boxes simply replace the easy to change lip seals and toss some black paint over it.
Overhauling these boxes is a skilled job best left to professionals.
MikeSimon
Re: steering box
« Reply #9 on: April 01, 2020, 14:48:49 »
It would be interesting to see a detailed comparison between the seal kits from the Aftermarket and Mercedes. A visual and dimensional comparo would already help. A material assessment will most likely not be possible as it would involve a chemical analysis. Someone with the personal/business interest, time and funds could attack that??
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
German specs
3rd owner
Aaron h
Re: steering box
« Reply #10 on: April 01, 2020, 20:41:59 »
I'll try to lay out an aftermarket kit and a Mercedes kit soon to show what is and is not included between the two.  I agree that any further analysis without specialized testing is going to be difficult.  Though, a dial caliper could possibly help with part of the physical analysis by taking measurements.
MikeSimon
Re: steering box
« Reply #11 on: April 02, 2020, 14:34:21 »
Yes! Exact dimensions are definitely necessary. Even small deviations in diameters and cross-sections of seals and O-rings always make a big difference in hydraulics
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
German specs
3rd owner
Pento
Re: steering box
« Reply #12 on: March 10, 2021, 15:04:15 »
Hi Aaron
How does the cylindrical valve shaft come out? My 'box is leaking from the weep hole as you describe. and I have the Meyle kit of seals and o-rings.
The box is out and partially disassembled.
Whats the cross-section diameter of the correct o-ring for the cylindrical shaft? The ones in the kit look too thin compared with the one I can see in the pump but need to get the shaft out before I can go further.
Appreciate any advice or instructions
Many thanks
Mark
