Author Topic: hood insulation pad  (Read 4535 times)
joelj
hood insulation pad
« on: March 08, 2005, 12:00:00 »
Hi guys,
I saw that a hood insulation pad is available through SL classics. I was wondering if this was standard equipment on a 69  280sl. I recently acquired my 280sl and noticed that my hood has no insulation pad.
Many thanks,
Joelj
Re: hood insulation pad
« Reply #1 on: March 08, 2005, 12:43:31 »
I don't think any W113 came with a hood insulation pad.
  • USA, VA, Alexandria
« Reply #2 on: March 08, 2005, 12:43:59 »
It was not standard or even an option.  One could apply a pad but it may cause excessive engine heat build up.   A properly tuned engine and valve clearances should make the engine humm-no need for the pad.
« Reply #3 on: March 08, 2005, 17:13:39 »
Originally posted by joelj
Hi guys,
Many thanks,
Joelj
I hear on good authority that you should NOT use a hood pad.  The hood was made of aluminum specifically to dissapate heat; blocking the heat transfer is asking for trouble.
