Author Topic: 22mm on VTG  (Read 2151 times)
Harry
  • USA, TN, Knoxville
22mm on VTG
« on: February 02, 2020, 14:46:37 »
What is the tightening torque for the 22mm fitting that secures the VTG in the block?  I’m leery about getting this too tight and putting too much load on the al/bronze thrust piece.
Thank you,
Harry
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
Re: 22mm on VTG
« Reply #1 on: February 03, 2020, 12:26:08 »
WTFIAVTG?
Re: 22mm on VTG
« Reply #2 on: February 03, 2020, 12:50:49 »
Must be the Vertical timing gear.
Harry
Re: 22mm on VTG
« Reply #3 on: February 03, 2020, 13:33:41 »
Sorry - Cees is correct.  I see that acronym so much on the Forum that I just assumed it was commonly understood.  (I'll do better on subsequent posts.)  Upon closer inspection, the torque of the 22mm Fitting does not impart a load on the VTG.  The Fitting threads into the Thrust Piece which is secured to the block with a 10mm bolt.
Harry
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
