Author Topic: Lower Wishbone / Control Arm Rubber Buffers  (Read 3403 times)
PeterPortugal
  • Portugal, Faro, Lagoa
« on: December 27, 2019, 11:17:38 »
OK guys, how on earth do I fit those pesky rubber buffers (shaped like bullets) into the sockets of the lower wishbones.
The mallet just bounces back off them !!
1963 220se Cabrio
1968 280se Coupe
Re: Lower Wishbone / Control Arm Rubber Buffers
« Reply #1 on: December 27, 2019, 14:24:07 »
I have no idea about these particular parts, but usually when I needed to fit thick rubber piece into the small hole (grommet, bumper, etc.) - vaseline lubrication did miracles.
450sl
« Reply #2 on: December 27, 2019, 14:33:18 »
Indeed, lubricant   then ''Screw" them in.
JohnnyC
  • USA, CA, Escondido, CA
« Reply #3 on: December 27, 2019, 16:45:41 »
Perhaps a little warming with a hair dryer (or low setting heat gun) to soften-up the rubber.  I'll be doing the same in the near future, thanks for the heads-up. I thought those would be difficult to install.
'70 280SL (In Rebuild), Dk Olive/Cognac
'85 BMW Euro M635csi, Polaris Silver
'54 MG TF, Black
'01 Lazy Daze RV, White/Tan
'10 Genesis Coupe, Silver
'19 F150, Black
PeterPortugal
« Reply #4 on: December 27, 2019, 23:23:22 »
I tried greasing before asking the question. Tomorrow I will try applying some heat too.
Appreciate the replies guys !
1963 220se Cabrio
1968 280se Coupe
PeterPortugal
« Reply #5 on: December 28, 2019, 14:51:24 »
Lubricant, lots of lubricant on both the rubber buffer and the socket it fits into.
I had to get my weight right over it but one it engages it goes straight in.
1963 220se Cabrio
1968 280se Coupe
winston the browndog
« Reply #6 on: January 03, 2020, 18:05:36 »
Do not use ,vaseline or wd-40 or lubricates like that , because if it helps slip things on it will help things slip off as well . You should use dish soap or liquid soap of some kind . The soap will dry out and on longer be slippery .
Paul
mbzse
« Reply #7 on: January 03, 2020, 18:41:13 »
Quote from: winston
.../... You should use dish soap or liquid soap of some kind. The soap will dry out and on longer be slippery
Very useful tip! Especially true for chassis rubber components. Do not apply grease! If this is used, the rubber parts will never "settle" and they may slip out of position, later on
« Last Edit: January 05, 2020, 15:16:12 by mbzse »
/Hans S
PeterPortugal
« Reply #8 on: January 03, 2020, 22:54:37 »
Guys
I will not remove mine and refit them after the struggle I had but I agree that people should try something like soap first. If it works, it is a better solution.
1963 220se Cabrio
1968 280se Coupe
specracer
  • USA, MA, Duxbury
« Reply #9 on: January 08, 2020, 01:24:22 »
I have used glycerine to install rubber seals etc with success.
« Reply #10 on: January 08, 2020, 14:40:05 »
Paul
I remember, actually, when I was working during holidays at my uncle's tyre service, we used soap water to mount tyres on  rims on the machine. It worked great. It was the 80-ies, communist time, and no special lubricant for that purpose was available, water with soap it had to be.
