Author Topic: Roof seals SL230 Scotland uk based  (Read 2621 times)
Por911t4
« on: December 15, 2019, 17:16:44 »
Hi, I’m looking for someone / or company that can supply and fit new roof seals all round to my ‘66 SL230. I’m based in Scotland uk . Would also consider a company in England . My roof is fine otherwise thanks Barry
Re: Roof seals SL230 Scotland uk based
« Reply #1 on: December 16, 2019, 14:49:01 »
Which roof seals? hard top, soft top or both.
The issue with changing seals (and I always use genuine Mercedes seals) is that you might find that the door glass no longer aligns with the seals and this can open up a can of worms, especially if you already have play in the door glass runners.
Here's the sequence:
Check doors for correct panel alignment; adjust if necessary.
Check door glass for correct operation; rectify & adjust as necessary any excessive friction or free-play.
Fit hard top and adjust door glasses to snug fit on weather seals.
Remove hard top and close soft top. Adjust soft top to align with door glasses.
I'm a fair way from you but you wouldn't be my most distant customer by a significant margin!
« Reply #2 on: December 16, 2019, 16:53:27 »
Merparts are in Glasgow
