Author Topic: Barometric compensator (BC) removal quick questions  (Read 3494 times)
gkrea1
« on: December 02, 2019, 13:37:37 »
Good morning.
1) What size wrench fits the hex section?  (17mm?)
2) Must a thin tappet-style wrench be used or is there another technique?  My search here last night didn't turn up anything.
-Greg
1967 230SL w/ 250 motor
Re: Barometric compensator (BC) removal quick questions
« Reply #1 on: December 02, 2019, 14:33:16 »
The baro requires a 19 mm wrench.  I think youre on the right track for its removal.  Been a long time since I replaced my baro
« Reply #2 on: December 02, 2019, 16:09:02 »
Be on the look out for thin shims under the BC when you take it out. Not sure why you are taking it out, but some use this to do a quickie full range fuel mixture adjustment. You can also test the compensator to make sure it hasn't failed while it is out.  https://www.sl113.org/forums/index.php?topic=12175.msg82217#msg82217
Jeff knows quite a bit about these pumps.
« Reply #3 on: December 02, 2019, 16:12:12 »
I walked out to the garage and slipped the fattest 19mm I had (.35 inches thick) onto the baro of my 1970 and it worked fine.
gkrea1
« Reply #4 on: December 02, 2019, 16:15:54 »
Thanks everyone.
I'll try a couple of 19mm's I have and see what'll squeeze in there.  Thanks for the reminder about the shims.
Yes, I suspect that it has failed or at least want to eliminate it as a variable in my starting & running issues.
« Reply #5 on: December 02, 2019, 17:05:43 »
When the baro fails, the system usually goes lean.
gkrea1
« Reply #6 on: December 07, 2019, 22:26:05 »
Thanks again, all.
I removed the BC and confirmed that it is kaput.
-Greg
