Author Topic: 1.5 inch Hole in Firewall  (Read 5807 times)
Charles 230SL
  • USA, GA, Griffin
  • 64 230SL
« on: November 27, 2019, 02:23:40 »
I've often wondered what the purpose is for the firewall hole pictured below. The hole appears to be factory and is blocked with a rubber plug. It measures approx 1 1/2 inch diameter.  I've looked through numerous photos of W113 firewalls but can't find anything using this particular hole.  any ideas? thanks, charles
WRe
Re: 1.5 inch Hole in Firewall
« Reply #1 on: November 27, 2019, 07:45:47 »
here you can see the defined firewall holes.
...WRe
Bob G MN
« Reply #2 on: November 27, 2019, 17:03:39 »
That looks like the hole for the trouble light plug in.  You do not have the plug in connector wired in that picture.  I believe it was an option.  you can still buy the light but today an led gives a lot more light
Charles 230SL
  • USA, GA, Griffin
  • 64 230SL
« Reply #3 on: November 27, 2019, 17:38:50 »
thanks Bob, but my trouble light plug-in (attached pic) is well above the hole that I'm referring to.
Looking at the picture provided by WRe, the hole appears to be the one on the driver's side labeled "Stopfen" but there is no corresponding hole on the passenger side. My car is a 4-speed; is it possible this hole would have been used for automatic transmission linkage?
« Reply #4 on: November 27, 2019, 19:03:07 »
stopfen translates (according to google) to plug.
The position I believe are the two drains from the scuttle box - air entry for the heater.
bogeyman
  • USA, NE, Omaha
« Reply #5 on: November 27, 2019, 19:07:37 »
Looks to me like #O on the pic which is called "gasgestange" or gas linkage.
Both of my 4 speed cars have a plug in that hole from the factory.
Rick Bogart
1969 280SL Silver(180)/Green
1993 500E
1972 350SL
1995 E320 Cabrio
dirkbalter
  • USA, CA, Corona
« Reply #6 on: November 27, 2019, 19:48:39 »
Yes, Stopfen means plug.
May be this helps. (Not my picture or car)
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
Peter h
« Reply #7 on: November 28, 2019, 00:50:58 »
Here a pic from my 280er schalter
Charles 230SL
  • USA, GA, Griffin
  • 64 230SL
« Reply #8 on: November 28, 2019, 13:46:04 »
all, thanks for the responses and photos.
Hope everyone has a great Thanksgiving!
« Reply #9 on: December 06, 2019, 02:14:21 »
My 1970 280 has the holes marked “Stopfen” they are about 20mm.  The one on the driver’s side is in the same location as yours.
« Last Edit: December 06, 2019, 02:46:04 by Shvegel »
col320ce
« Reply #10 on: August 13, 2021, 00:12:02 »
I translated the holes from WRe's picture into English :
1 fuses
2 socket
3 Tachometer Shaft shaft, water thermometer
4 speedometer cable, oil pressure
5 fastening bkv
6 washer fluid hose, hood lock
7 wiring harness
8 heating inlet / outlet
9 access heating valve
10 throttle rod
Col
1964 230SL
1965 250SE coupe
1993 320CE Sportline
« Reply #11 on: August 13, 2021, 05:43:10 »
The holes marked "Stopfen" are, I think, just technological holes (for paint) used then also for maintenance (e.g. wax application). The plug to fill them is A1139870044. There is a lot of these plugs in the car...
