Author Topic: wanted to buy  (Read 5174 times)
cory marcus
wanted to buy
« on: November 23, 2019, 23:43:24 »
Im looking for following. for my 1970 280sl
1. original  tool kit in brown
2. brown crank handle pad in brown
3. set of white plastic screws to fasten trunk light assembly
Vander
  • USA, OH, Columbus
Re: wanted to buy
« Reply #1 on: November 24, 2019, 00:22:54 »
MMizesko will have your complete tool kit.
Re: wanted to buy
« Reply #2 on: November 24, 2019, 15:34:26 »
Cory, you may want to check, but following some discussions on this Forum I came to conclusion that 280SL had black thumb nuts for their headlight assemby in the trunk (late style), e.g. https://www.sl113.org/forums/index.php?topic=28383.msg205095#msg205095
You can buy them at Mercedes dealer, A 111 990 02 57, should be $5-6 dollars per piece, you need 4 for 280SL late style, they hold the bulb holders, not the entire lamps, unless you have other type of lamps where you need to remove the entire lamp to get to bulbs.
« Last Edit: November 24, 2019, 15:46:25 by Pawel66 »
cory marcus
Re: wanted to buy
« Reply #3 on: November 25, 2019, 20:04:10 »
Thanx very much for your valued information.
Cory
cory marcus
Re: wanted to buy
« Reply #4 on: December 14, 2019, 22:27:10 »
Where would I dind MMizesko to locate a 280sl tool kit?
MikeSimon
  • USA, OH, North Royalton
Re: wanted to buy
« Reply #5 on: December 14, 2019, 22:57:50 »
Pawel: was that a special option? "headlight assembly in the trunk" … Have not seen that and mine does not have them. ??? ??? ;)
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
Re: wanted to buy
« Reply #6 on: December 14, 2019, 22:59:45 »
Cory,
Search the members list Mike is under Mizesko and you will then be able to send a PM or email to him
Re: wanted to buy
« Reply #7 on: December 15, 2019, 09:24:13 »
Mike, my mistake - tail light, not headlight obviously, sorry - I was saying that late 280SLs might have had black thumb nuts in the trunk for their late style tail light assembly. These black thumb nuts were holding just the bulb holder, not the entire tail lamps. If this conclusion is true or not - that is another story, I came to think that after the discussion on this topic.
