Author Topic: Correct battery for 1969 280SL  (Read 6211 times)
TBaker
  • USA, TN, Germantown
« on: November 07, 2019, 20:40:43 »
What options do I have for the correct battery for my 280SL, using the OEM battery holder?  My mechanic recently installed a new Champion battery but the posts are lower than the surface of the battery and my battery top holder will not fit this battery.  Can I just use any 12 volt battery, such as Interstate, which has the compatible battery posts?
Mpfalkowski
  • USA, CT, Suffield
Re: Correct battery for 1969 280SL
« Reply #1 on: November 07, 2019, 20:44:52 »
I was fortunate to purchase a Mercedes Benz one from the local dealer; fit and looks nice.
Matt Falkowski
1971 280 SL
TJMart
  • USA, NC, Matthews
« Reply #2 on: November 07, 2019, 20:47:30 »
It's best to measure the bracket and the base tray and height if you are using a non Mercedes battery. I just bought the Mercedes battery as well and it fits perfectly.
Tony
1970 280SL, 4 Speed
« Reply #3 on: November 07, 2019, 21:00:42 »
I do have a Mercedes-Benz correct battery, but it is some years old now and I don't use it except for shows.
My daily battery is a DieHard Group 34R (R=reverse polarity on posts to match our cables) Gold AGM; that's a sealed gel battery. The OEM top bracket and holder work fine.
mrfatboy
  • USA, CA, Rancho Santa Fe
    • Mrfatboy
« Reply #4 on: November 07, 2019, 21:27:37 »
You can get a Pep boys Bosch battery that fits well.  $100-$120 depending if it's on sale.
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
Bonnyboy
  • Canada, BC, North Vancouver
  • 1969 280sl Euro 4sp LSD
« Reply #5 on: November 07, 2019, 21:45:37 »
Be careful to make sure the battery you get will actually fit.
I was getting ready for a rally the next day and decided that my current battery just wasn't holding a charge and I didn't want to be stranded so I called my battery place a big bridge and couple municipalities away and he said they had it.  He answered yes pretty quick but I put that down to "knowing his stuff".
Once I got there just before closing the parts guy said that they didn't have the exact replacement for mine but they "had the correct battery for my car".  He made a comment that I should have had the correct one all along.   I compared and they looked very similar.
I bought it, took it home and getting ready for the rally the next day I realized the new battery didn't fit as it had these angular tiedown ledges along the bottom that wouldn't fit in the tray.  So I had to grind off those angular ledges  to get it to fit.  I would have taken it back but it was sunday morning 1 hour before the rally that I discovered the issue and I really wanted to go play with my car.   I figured it was worth the inconvenience to go on a rally with my daughter as copilot.
So just make sure it fits and mine was a bit of a pig to fit in the hole needing to be tipped over where acid leaked out a bit.  So be careful.
I can't remember the one that fit but I think it was noted to fit a later sedan as well.
Ian
69 280SL
73 CB750K
75 MGB
78 FLH
82 CB750SC
83 VF 1100C
94 FLHTCU
96 F-150
08 NPS50
12 Pro 4X
mrfatboy
    • Mrfatboy
« Reply #6 on: November 07, 2019, 21:54:31 »
The pep boys battery fits fine.  Take off the new Bosch decal and use the vintage one available in the members section of this forum.
The new version of the battery has no caps and is solid black on top.
Signal Red
4 Speed
john.mancini
  • USA, FL, Nokomis
« Reply #7 on: November 11, 2019, 18:56:23 »
If you live in the U.S., there are antique battery companies out there that make reproduction batteries for many cars of the 50's and 60's, including all U.S. auto manufactures and some European. Unfortunately, MB has not given these companies the permission to use the MB name. Same with Bosch and Varta. They do however make Lucas batteries in the correct size and appearance. These are sealed batteries that have basically the same dimensions as the original batteries found in the 113's. They look identical to the old tar top batteries, series 24.
« Last Edit: November 11, 2019, 19:19:29 by john.mancini »
65 230SL 519 Red 4-sp
98 911 cab
56 Ford F100
08 Porsche RS60 Spyder
23 Z4M40i
« Reply #8 on: November 11, 2019, 20:08:55 »
Battery dimensions are in the tech manual
john.mancini
  • USA, FL, Nokomis
« Reply #9 on: November 12, 2019, 21:44:29 »
Yes, the original battery was 10 1/4" X 6 13/16" X 8 3/4" ( 260mm X 180mm X 222mm)
The Lucas reproduction series 24 Tar Top batteries are 10 1/4" X 6 3/4" X 9". Nearly a perfect fit and period correct in appearance.
98 911 cab
56 Ford F100
23 Z4M40i
lowpad
  • USA, CT, New Preston
« Reply #10 on: November 13, 2019, 02:36:25 »
So what is the source of the Lucas tar-top battery?
1966 230SL (6/66 build)
French export
4-speed manual
158 Exterior / 040 Hardtop
2001 SLK230
1996 Porsche 993
1991 Acura NSX
john.mancini
  • USA, FL, Nokomis
« Reply #11 on: November 13, 2019, 14:04:23 »
antiqueautobattery.com       They are located in Youngstown, Ohio. I have purchased many reproduction batteries from them over the years for collectible 1960's Corvettes and Mustangs. Their batteries are excellent reproductions and pack plenty of power. Maintenance free.
98 911 cab
56 Ford F100
23 Z4M40i
marshall
« Reply #12 on: July 21, 2020, 14:30:07 »
Could you let me know the exact numbers for this battery? Group number, etc.  thanks
marshall
« Reply #13 on: July 21, 2020, 14:33:19 »
Please let me know the Group number, etc. for this battery so it will fit well in my '71 280SL. Got a new hold down frame and it doesn't fit with the Bosch battery currently in the car.
thanks from suburban Philadelphia!
WRe
« Reply #14 on: July 21, 2020, 16:30:43 »
the original black Bosch battery had the part no. F 026 T02 311 and size  260 x 173 x 225 mm: http://www.bosch-classic.com/en/internet/bosch_classic/produkte/serviceteile/batterie_1/batterie___mit_teaser_1.html.
...WRe
