Author Topic: disassembly of doorhandles  (Read 3418 times)
jan lauwers
  • Belgium, Antwerpen, Geel
« on: November 03, 2019, 17:26:37 »
Gentlemen,
I have now entered the stage of the body restoration and I am preparing my 280SL for a repaint job. With that comes re-chroming and a new interior and soft top.
I 'd like to remove the cylinders of the door handles so that I can have the (empty) handles re-chromed. I first tried on the trunk lock... I managed that, so now I am encouraged to do the same on the door handles.
I have read through all (I think) the posts on this forum about the disassembly of the door handles, but I have not found the answer to my question:
How do I remove the cylinder (the part that you push with your thumb to open the door), from the doorhandle casting? I have removed the circlips and the spring. What is the next step now? (see pic please, this is how far I have gotten).
Jan Lauwers, Geel, Belgium
Grey (Used to be white)  280 SL 1969
badali
  • USA, Pa, Butler
  • 1966 230SL
Re: disassembly of doorhandles
« Reply #1 on: November 03, 2019, 17:47:45 »
You may have to insert the key.  I have done this with other locks.  It levels the pins and it should slide out.
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
2022 GLC 300 4 Matic
2025 E53 AMG Sedan
jan lauwers
« Reply #2 on: November 03, 2019, 18:36:41 »
Thanks, Badali,
I have not made myself clear. I have inserted the key and then, indeed the cylinder comes out. However, I want the housing that holds the cylinder to come out.
Jan
« Reply #3 on: November 03, 2019, 19:31:49 »
Hi Jan,
There is a ring (see blue arrow) which you can take out with a screwdriver.
Then the you can take out counter ring, spring and the cylinder.
Succes, Peter
« Reply #4 on: November 03, 2019, 19:34:41 »
other picture
jan lauwers
« Reply #5 on: November 03, 2019, 19:50:21 »
Ok Peter, this woked, thanks a lot for your help. Great forum!
Jan
