Author Topic: THERMO - TIME SWITCH AND 17 DEG THERMO SWITCH CLARIFICATION REQUIRED  (Read 3200 times)
Nicolas Aristodemou
  • Cyprus, Lefkosia, NICOSIA
  • 280SL Auto 1970 W113, 380SL Auto 1982 R107
As per wiring diagram for the USA 280SL with emissions control (from Technical Manual's Electrical section), the thermo temperature switch (shown as number 31 in the schematic, provides ground to the  cold start valve solenoid (shown as number 21) which in turn powers the cold start valve (shown as number 32). So far so good.
Another thermo-switch called the 17 deg C shown as number 35 on the same electrical schematic controls the operation of the emissions control vacuum switch via the relay box (33)  and speed control relay (50).
I was under the impression that these two devices were the one and same device. If they are 2 distinct devices where then is the 17 deg thermo-switch located?  Above spark plug 6 is the thermo time switch with its two terminals G and W.
If on the other hand they are the one and same device then terminal W of the  thermo-time switch should go not only to the cold start valve relay (21) but also to terminal 6 of the relay box (33 in the schematic).
Any advice please?
Nicolas Aristodemou
Nicosia - CYPRUS
280SL Auto 1970 US spec (W113), 380SL 1982 R107, Citroen DS23 Pallas 1973, Triumph TR4 1963, Triumph Stag 1973, Mini Cooper S Mk1
1965, Jaguar 3.8 Mk2 1962, VW Beetle 1978 Karman Converible, 1987 Ferrari 328GTS
Re: THERMO - TIME SWITCH AND 17 DEG THERMO SWITCH CLARIFICATION REQUIRED
« Reply #1 on: October 20, 2019, 19:01:20 »
That switch is much smaller and is located below and just behind the IP.
Nicolas Aristodemou
« Reply #2 on: October 20, 2019, 19:16:03 »
Thanks a lot..... that now makes sense.....
Nicolas Aristodemou
Nicosia - CYPRUS
