Author Topic: Winter 2019/2020 Project  (Read 4132 times)
Chris Long
  • USA, NJ, Morristown
« on: October 14, 2019, 12:50:30 »
Please advise if this is the wrong section but most of the work fits in this area. I'll have lots of questions I'm sure as I undertake my first major winter project and wanted to create a single thread for everything. I had the shocks (billsteins) and engine/transmission/subframe mounts replaced in spring and want to now tackle the rest of the rubber.
Trying to be logical and given having to remove the radiator anyway it seems like a good idea to tackle a few front of engine jobs at the same time...
Appreciate thoughts on if I'm missing anything major...
List of Projects:
- Refinish wheels and new whitewall tires
- Sway Bar and Leaf Bushings
- Cooling system
   + Replace radiator (small leak)
   + New hoses
   + New water pump
   + Flush
   ? New thermostat
- Oil System (whilst having to remove radiator anyway)
   + New heat exchanger
   + New heat exchanger hoses
   + Crank Seal (currently leakng)
   ? Sump / sump seal
- Clean Speedometer glass
   + New ring/seal
   + New bulb
   + Fix rattle on horn ring (whilst wheel off for speedomter removal)
Servicer
   + Air Filter
   + Oil Filer
   + Fuel Filter
   + Plugs
1970 280sl 4-Speed Horizon Blue
Vander
  • USA, OH, Columbus
Re: Winter 2019/2020 Project
« Reply #1 on: October 14, 2019, 15:00:17 »
When doing a service, don't forget to re-torque the head and do a valve adjustment.
Send your radiator out to a local radiator shop and have them re-core it.
Chris Long
« Reply #2 on: October 14, 2019, 16:56:48 »
Controversial I know, but I'm going to try the Haas Classic replacement radiator and the oil cooler from Classic Mercedes Parts (Belgium).
I looked around locally at a few radiator shops but non gave me confidence so I've opted for new. If it doesn't fit it still leaves me the option of a recore.
All the other parts are OEM / Authentic Classics.  I'll post up pictures as I go and parts arrive.
Will look at the top end work but mechanic that did the engine / subframe mounts indicted that all was well...
Iconic
  • USA, IL, Highland Park
  • ex-Membership Administrator
« Reply #3 on: October 14, 2019, 17:26:10 »
I believe you forgot the more than 20 grease zerks that need grease.
Also, depending on how old your water pump is, why not change it out since you have the cooling system drained and the radiator out of the way?
Have fun !!
Mark
1998 BMW M-Rdstr Estoril Blue
« Reply #4 on: October 14, 2019, 23:16:05 »
I have the Haas Radiator.  It fits perfectly.
Chris Long
« Reply #5 on: October 16, 2019, 23:41:20 »
Any suggestions on a puller for the harmonic balancer?
lurtch
  • USA, CA, Santa Rosa
  • " ICON 66 "
« Reply #6 on: October 17, 2019, 00:03:16 »
A trip to Home Depot got the Harmonic balancer job done for me - -
Larry in CA
Larry Hemstreet  in  N. Cal.
1982  300TD-T (parted out)
1986  560SEC (totaled)
1991  300TE (gifted)
1998  E320 (sold)
2004  E320 wagon (gifted)
2008  CLK550 Cabriolet
pj
  • Canada, ON, London, Ontario
  • 1965 230SL
    • my home page
« Reply #7 on: October 17, 2019, 07:07:18 »
Someone please tell me what a "harmonic balancer" does. So much to learn!
Peter J
1965 230SL #09474 named Dagny
2025 GLC300 coupe named Rigel
« Reply #8 on: October 17, 2019, 15:30:38 »
Very creative "lurtch"
MikeSimon
  • USA, OH, North Royalton
« Reply #9 on: October 18, 2019, 18:30:26 »
If you consider that the rotation of an engine is not at all "smooth" or consistent but follows the combustion impulses of the cylinders - in case of our SLs, 3 impulses per rotation - the crankshaft faces forces that lead to vibration which could cause damage to the crankshaft or other parts of the engine or car.
A harmonic balancer takes out these forces, usually through rubber inserts in the crankshaft pulley. It is also sometimes called "dampener".
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
