Become a
Full Member
Emergency Contact List
230sl fully re built engine and injection pump causing plugs to be coated in oil
Topic: 230sl fully re built engine and injection pump causing plugs to be coated in oil (Read 3333 times)
Raffles84
October 05, 2019, 12:53:11 »
Hi, my 230sl engine has been fully rebuilt and also the injection system - now it’s covering the plugs in oil and burning oil when turned on! Any ideas what to check??
Tyler S
Associate Member
Platinum
USA, CA, Encinitas
Re: 230sl fully re built engine and injection pump causing plugs to be coated in oil
October 05, 2019, 13:27:36 »
How many miles/km is on the engine?
Remove the oil cap while the engine is idling and check for blow-by.
Also be sure you are NOT using synthetic or synthetic blend oil during break in.
Raffles84
Reply #2 on:
October 05, 2019, 14:00:40 »
The engine has been fully re built and all new pistons etc! Using Castrol Classic oil specially for this pagoda. Thanks
Tyler S
Associate Member
Platinum
USA, CA, Encinitas
Reply #3 on:
October 05, 2019, 14:12:52 »
Check for blow-by as it may help point you in the right direction being valve guides/seals or oil control rings. How many miles on the rebuild?
Full Member
Platinum
USA, OH, Blacklick
Reply #4 on:
October 05, 2019, 14:24:08 »
If it is an automatic, make sure you are not sucking up transmission fluid into the engine. Are all the spark plugs, getting oil on them?
Raffles84
Reply #5 on:
October 05, 2019, 17:17:28 »
Hi it’s had no miles on the rebuild was trying to get it running a bit before I send it for tuning. Just started and ideled a bit
Full Member
Platinum
USA, CA, DeLuz and France, Haute-Marne, Guyonvelle
Reply #6 on:
October 05, 2019, 19:31:34 »
Could it be the assembly lube burning off?
Tyler S
Associate Member
Platinum
USA, CA, Encinitas
Reply #7 on:
October 05, 2019, 23:30:22 »
With zero miles it needs to be broken in. If you can get it started hold the rpm at around 2000 for 10 minutes. Then put some miles on it with differing speeds.
Full Member
Platinum
USA, OH, Blacklick
Reply #8 on:
October 06, 2019, 00:01:58 »
Yes could be sucking in assembly lubes. Did they bore the block along with new oversize pistons?
Raffles84
Reply #9 on:
October 06, 2019, 07:22:36 »
Yes the block was bored and new pistons etc. A complete re build was done.
Full Member
Platinum
USA, OH, Blacklick
Reply #10 on:
October 06, 2019, 15:33:47 »
You might have to install a fresh set of plugs and run it a bit more to clear up the problem or determine the issue.
