Please check out joining the
Emergency Contact List
for help during your travels!
Electrical and Instruments
Headlight glass. Flat or rounded?
Topic: Headlight glass. Flat or rounded? (Read 3969 times)
Paul99
Full Member
Silver
United Kingdom, England, Hampshire UK
230 SL White. 1966.
September 22, 2019, 15:49:11 »
I have seen a couple of pagoda where the headlight glass is flat Vs mine which are curved. Not the USA type sealed beam ones. The standard euro ones.
Which is correct and did they change over the years ?
Tyler S
Associate Member
Platinum
USA, CA, Encinitas
Re: Headlight glass. Flat or rounded?
September 22, 2019, 16:06:08 »
The flat glass style was used in the halogen fixtures that had 2 separate halogen bulbs. If your fixture uses a single headlamp bulb incorporating 2 filaments (low and high) then the curved lens is the correct one.
https://www.sl113.org/wiki/Electrical/EuropeanLamp
Associate Member
Platinum
Canada, ON, Port Lambton
Reply #2 on:
September 22, 2019, 19:55:49 »
I prefer the rounded ones anyway. They're much stronger and won't break as easily as flat glass.
1966 230SL 5 speed, LSD, header pipes, 300SE distributor, ported, polished and balanced, AKA ''The Red Rocket ''
1970 3.5 Coupe
1961 190SL
1985 300CD Turbo Coupe
1981 300SD
2013 GMC Sierra
1965 230SL
Paul99
Full Member
Silver
230 SL White. 1966.
Reply #3 on:
September 23, 2019, 13:33:35 »
Great thanks. Mine are rounded as it's a 1965/6 built car. Looks correct.
Another question. When you replace the standard bulbs for halogen brighter bulbs do you remove the silver shades that sit in front of the old bulbs or keep them in place?
Full Member
Platinum
Australia, Victoria, Kyneton and Brisbane Queensland
Audit Committee
Reply #4 on:
September 23, 2019, 13:41:58 »
Paul,
Suggest you fit LED’s, they are really twice as good as the originals and far better than halegon.
1972 MB 280CE W114 Auto RHD 906G
Guanaja
Full Member
Junior Level
USA, NM, Albuquerque
Reply #5 on:
September 23, 2019, 20:56:03 »
RE LED headlight bulbs, can you provide more detail, brand or model number for the bulb? Is this a direct replacement or require further modifications?
Full Member
Platinum
Audit Committee
Reply #6 on:
September 23, 2019, 21:24:41 »
I don’t have the details with me, search on LED headlights, there was some discussion recently and have a read through this post here for others.
https://www.sl113.org/forums/index.php?topic=22863.msg183730#msg183730
They are direct replacements depending on your current ones. Some need a tag removed by file.
