Author Topic: Detailing the 280SL Engine  (Read 12114 times)
NYC-MB280SL
« on: September 04, 2019, 16:44:13 »
I have a 1968 280SL and am about to undertake a major detailing of my engine bay. I've noticed that many of the restored SL's (including those done by MBUSA Classic Center) are now being shown with a yellow finish on the metal pipes, bolts and gas lines. I assume this is some sort of zinc oxide finish to prevent rust.
Does anyone have any experience or helpful hints on this process to share?
Why in a world so obsessed with original detail, would so many high end car owners make this modification from original?
Peter Paris
Re: Detailing the 280SL Engine
« Reply #1 on: September 04, 2019, 16:56:06 »
That yellow finish is the original color for this generation of cars. It is called yellow zinc or possibly could be yellow CAD. There are many posts about this on this site. Over time, the yellow finish (chromate) vanishes and leaves the silver zinc or CAD plated finish. Once that plated finish wears away, the pipes will start to rust. The yellow chromate is a protective coat for the vulnerable zinc plate finish. Nothing lasts for ever. But the yellow chromate is for sure correct on most items in the engine bay.
« Reply #2 on: September 04, 2019, 17:29:12 »
Peter,
Research is key to a good job if your goal is originality.  There are many changes that occur not only at year breaks in production but at mid year points as well.  Start by searching "original 280SL for sale"  When you search there will usually a photo of the VIN tag or body tag.  Try to find a VIN as close to your's as possible.  After spending hundreds of hours researching my particular niche in the production chain here is what I figured out.  Original cars are usually more accurate than restored ones.  Ignore any sales brochures you may see online as many cars were spruced up for the brochure photo.
Save everything that comes off the car and gets replaced.  Even old clamps may be of a design that is no longer made.  Original spark plug wires can have their wire replaced very easily and be more correct than new ones.
If you are really into the hair splitting details you will notice little paint swipes at various places under the hood.  These are referred to as Dotology and are the marking to indicate that a fastener or assembly had been checked for tightness.  Document them and put them back.  Below is a photo of the dots at the back of the brake booster.
Start by going here:  http://historic.motoringinvestments.com/MainPage.htm   Go to Mercedes for sale and down to the white one labeled as the "Holy Grail"  Although this is a 1969 you will see many of the details are the same as your year.   Use these as sort of a benchmark as to what a truly original car looks like then start looking for the 1968 you need.
teahead
  • USA, WA, Des Moines
  • aka "Rob"
« Reply #4 on: September 04, 2019, 18:00:34 »
Teahead,
I like the original photos before restoration of the Gelson car for those of us with late 70 or early 71 cars because it has a lot of deep photos and not just the surface ones.  However, a couple things to be aware of in the restored photos are the rubber plugs on the inner wheelhouses should not be there as the holes were left open on the later cars, the alternator between the housings was a clear varnish and not red Glyptal and I believe the serial number on the frame rail was simply stamped in over the paint and doesn't have the "Box" around it like the earlier cars. I am curious how your's is?
This is a pretty nice 68 with some small issues like those horrid hose clamps.  All clamps should match(Authentic Classics sells sets) except the power steering return hose clamps which are of a special design.
https://scottgrundfor.com/sale-1968-mercedes-benz-280sl/
« Last Edit: September 05, 2019, 19:56:22 by Shvegel »
49er
  • USA, CA, El Dorado Hills
« Reply #5 on: September 04, 2019, 18:20:49 »
 Have posted this photo many times and easier to just do it again then try and find one of those posts :-[ Picture taken of mine a few months after delivery. Castrol sticker put on by dealer.
1969 280SL 003820
4 speed manual, PS. 77K+miles
MikeSimon
  • USA, OH, North Royalton
« Reply #6 on: September 04, 2019, 18:23:17 »
Interesting! I always though the cars had an emission sticker of some kind on the valve cover from the factory. Mine still has the remnants of it and I cannot find a replacement. That has kept me from refinishing the valve cover.
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
49er
« Reply #7 on: September 04, 2019, 19:32:21 »
Here is a poor quality B&W taken the evening I brought it home from the dealer. Sticker was on the other side. I kick myself that I didn't take dozens of pictures back then but again, I never thought I would still be driving it 50+ years later :).
« Last Edit: September 04, 2019, 20:34:38 by 49er »
1969 280SL 003820
« Reply #8 on: September 04, 2019, 20:24:14 »
Mike,
The valve adjustment stickers began in 1970.  Your's being a Euro model has only the valve adjustment and timing sticker.  Mine (I believe) being the US  version has both the valve adjust sticker and the US Emissions family sticker as well.
49er,
Thanks for clarifying the Castrol sticker.  I always wondered about that since your's was the only one I have seen.
« Last Edit: September 04, 2019, 21:48:36 by Shvegel »
Tyler S
  • USA, CA, Encinitas
« Reply #9 on: September 04, 2019, 21:00:13 »
neelyrc
  • USA, AL, Birmingham
« Reply #10 on: September 04, 2019, 21:08:56 »
For those following the “paint”, “no paint”, hood latch bolt debate, note the body color paint on John’s hood latch bolts.
Ralph
1972 Mercedes-Benz 280SEL 4.5
1988 Mercedes-Benz 560SL
2007 BMW 328xi (E90)
Italy
2004 Toyota HiLux D4D Pickup
« Reply #11 on: September 04, 2019, 22:51:13 »
I noticed that the safety catch isn't painted either.
49er
« Reply #12 on: September 04, 2019, 23:38:45 »
 It is painted but just a dull black. Maybe shinier when new?
1969 280SL 003820
Tyler S
« Reply #13 on: September 05, 2019, 00:19:03 »
The safety catch is dark cad plated (dichromate). Here is a NOS one
49er
« Reply #14 on: September 05, 2019, 00:33:30 »
I stand corrected, thanks Tyler
1969 280SL 003820
« Reply #15 on: September 05, 2019, 01:43:11 »
Quote
What I am always wondering about, John, ???
is why your car - which is clearly a US-Version (code 49/1) - doesn't have any sort of emission control relays or stuff behind the battery.
All US-version 280ies should have that..., even the late-style 250ies US had that to some amount..., so why not yours?? ??? ::) :-[
https://www.sl113.org/wiki/Electrical/EmissionControlSystem
Just very much wondering...,
Tyler S
« Reply #16 on: September 05, 2019, 02:39:22 »
Achim, Its all there. The only emissions item on the late 250, early 280 was the fuel cut solenoid. And that was controlled by a microswitch only. A relay for controlling that system didn't appear until very late 1968 production. So in his photo is the enrichment relay, cold start relay, and wiper relay next to the washer bottle. Looks identical to my late 250sl.
Tyler
« Last Edit: September 05, 2019, 02:45:35 by Tyler S. »
MikeSimon
« Reply #17 on: September 06, 2019, 12:32:08 »
Thank you for the link, Tyler! They indeed had the label I am looking for!
I ordered it for $14.-, but they charged $12.65 for shipping :o :o >:( Something that fits in an envelope and mails for 55 Cent. Put a red flag next to them on my list of vendors.
 Anybody have the same experience with these guys?
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
German specs
3rd owner
Tyler S
« Reply #18 on: September 06, 2019, 13:36:46 »
Mike, That is most likely some sort of shipping software at work. Perhaps send them an email and see if they can ship it in an envelope and adjust the cost.
When buying items for the cars I try to make it a habit to have a running list of additional items (want list) so that shipping charges get combined.
« Reply #19 on: September 06, 2019, 16:47:20 »
Mike,
Are you sure that label is right for your car?  Look at CO etc.  almost positive the Euro cars have a different label.
MikeSimon
« Reply #20 on: September 06, 2019, 18:51:04 »
Pat:
As usual, I was too quick, got too excited. And not being at home did not help. Upon checking the decal, you are right, of course. My original is (was) quite different
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
German specs
3rd owner
« Reply #21 on: September 06, 2019, 21:27:48 »
Mike,
49er,
Can you tell more about it? How exactly these stickers looked like for Euro version and where were they placed? I was chasing this once - it seemed Euro cars did not have that sticker. I would be very interested how it looked like and where was it placed...
MikeSimon
« Reply #22 on: September 06, 2019, 23:54:41 »
Pawel, I have been chasing that sticker for quite some time without success. As you can see in the picture I posted, there is not much left of it and I cannot say exactly what was on it. As you can also see in the picture, the sticker/decal is on the right side of the valve cover, sort of next to the Mercedes star, between the two mounting bolt cut-outs. And it does not refer to the M130 engine, but the vehicle applications 280SE/8, 280SL/8 300SEL/8. Right along the line of my mystery cylinder head, which says 280SEL/SL
« Last Edit: September 06, 2019, 23:59:15 by MikeSimon »
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
German specs
3rd owner
« Reply #23 on: September 07, 2019, 00:36:52 »
Mike,
Have you contacted the Classic Center in Germany?
« Reply #24 on: September 07, 2019, 08:37:30 »
Ok, thank you! At least I know what I am chasing now and the location! I will start digging too.
