Author Topic: Bolts that hold the fuel pump cover  (Read 4042 times)
Rhinkel
« on: August 11, 2019, 06:10:01 »
I am missing the fuel pump cover, long pump, and the 3 shouldered bolts that go through the trunk pan on my 69280 SL. I can find the cover easy enough but not the special bolts. Anyone have a source ? Thx
Re: Bolts that hold the fuel pump cover
« Reply #1 on: August 11, 2019, 06:13:25 »
These are special bolts with a square clip built into the head of the bolt. They secure into a square hole in the trunk floor. Your local MB dealer can order them for you. Also I think I saw them on the Authentic Classics website.
« Reply #2 on: August 11, 2019, 08:13:04 »
Here you have the link to source for Europe and Mercedes PN is there as well:
https://www.niemoeller.de/en/w113/w113/B044/472/c47017a-screw-with-locking-plate
WRe
Rhinkel
« Reply #4 on: August 11, 2019, 14:31:52 »
Wow. Thank you for the info.
« Reply #6 on: August 11, 2019, 19:52:09 »
I used regular bolts, about $4 for 10.
mbzse
« Reply #7 on: August 11, 2019, 21:08:52 »
Quote from: ja17
These are special bolts with a square clip built into the head of the bolt..../...
One important feature of these bolts and the mounting of the fuel pump housing/cover are the seals, otherwise water may enter the trunk at these three points
/Hans S
« Reply #8 on: August 12, 2019, 04:32:23 »
On top of the sealing feature, they also look "civilised" in the trunk and, as they click in place, one pair of hands is enough to install them.
« Reply #9 on: August 12, 2019, 05:12:39 »
I sealed the holes with a washer. They are covered by the rubber trunk floor mat so invisible.
Rhinkel
« Reply #10 on: August 12, 2019, 14:21:43 »
Got them on order. Thx
