Author Topic: Cylinder head gasket replacement ....  (Read 3328 times)
Por911t4
« on: August 09, 2019, 07:52:54 »
My '66 230 just wasn't running as it should …. slow to pull away, underpowered and just generally unhappy. So head off and the gasket is in a poor state (stuck down with Hylomar to cover an uneven surface), there is play in the valve guides and the valve seats are also in a poor state. Not the best news but good that we've found some issues. Also going to renew the timing chain and guides etc. in addition were going to fit electronic ignition . So really looking to get it tip top for next summer as this summer is slowly slipping away ...
Re: Cylinder head gasket replacement ....
« Reply #1 on: August 09, 2019, 14:05:54 »
Good going - if the timing chain is worn, you will pick up power right there due to better engine timing. Can recommend the 123 ignition, go with that, and that is another improvement. Sounds like the machine shop will be looking to skim the head if it's uneven, make sure it can handle it, thickness-wise.
Por911t4
« Reply #2 on: August 09, 2019, 14:20:21 »
Thanks Cees,
Great input thanks ! The head appears to be original which is a good thing (ie not previously skimmed). The electronic ignition seems the right thing and Im glad you can vouch for it. Here's hoping for some driving improvements once complete !
Many thanks again
Regards Barry
« Reply #3 on: August 09, 2019, 20:33:27 »
Looks like it might have had the wrong head gasket on it also?
« Reply #4 on: August 09, 2019, 21:38:08 »
Not sure where you see that but I would be inclined to pull the engine and have the whole block boiled out. It looks like it's chock full of rust.  Sometimes there's no cheap or easy answers.
Remember; there's never enough time to do something right but there's always lots of time to do it over again.
MikeSimon
  • USA, OH, North Royalton
« Reply #5 on: August 09, 2019, 23:25:52 »
Joe may have something there. The pattern that the head gasket left on the block looks somewhat like a cross between 'oval" and "square" gasket.
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
mrfatboy
  • USA, CA, Rancho Santa Fe
    • Mrfatboy
« Reply #6 on: August 10, 2019, 00:58:17 »
Can you post a picture of the gasket?
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
