Author Topic: Rev cable  (Read 3000 times)
jan lauwers
  • Belgium, Antwerpen, Geel
Rev cable
« on: July 15, 2019, 19:46:04 »
Hi guys,
I am stripping my car in preparation for a repaint.
Right now I am working on the dash and I this afternoon I removed the rev counter. I noticed that the thin metal rev cable is sticking out quite a bit of its black hoose. In fact, it is sticking out so much that I can not bring the cable nut anymore close to the back of the rev counter to screw it back on. I also noticed that, when I switch the engine on, (with the rev counter out) I don't see the cable turning...while I think it should be turning, no? Has it somehow disconnected from the engine?
Should I detach the cable on the engine side, to fix it back correctly in its hoose? Problem is that I can't access it there; IP and other items are sitting in the way.
Any thoughts, please?
Thanks, gentlemen!
Jan
Jan Lauwers, Geel, Belgium
Grey (Used to be white)  280 SL 1969
Re: Rev cable
« Reply #1 on: July 15, 2019, 19:52:39 »
Re: Rev cable
« Reply #2 on: July 15, 2019, 23:10:27 »
Just rotate the core and feed it back into the housing. Sounds like the core dis-engaged at the engine end. If that does not work dis-connect it at the engine and fit it up there first.
